Home > Faults & Fixes > Suspension fault. Normal height only
Page 2 of 3 <123>
Stevepd
Me too, I got Normal height only this morning. Drove to work switched off then on and warning disappeared. Battery is 2 years old. If it pops up again I may look into it.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #570353 Mon Dec 03 2018 2:59pm
samd
Father Jack wrote:
Not a bad idea. I tend to put mine in access height every time I park up just out of habit.
I think the height also lowers a bit at over 100mph but of course there is nowhere legal in the UK to test that 😃
Mine 'went' a couple of months ago and I was told it's 60mph where the car lowers and that makes a bit of sense in that every time I got to 60, the message came up reminding me to stay at 30!!
In my case, the reason was nothing more than a frayed wire - couple of bob at the Indie - sorted.
Post #570354 Mon Dec 03 2018 3:14pm
Plazmapete
Depends what compressor you have. The Hitachi or Dunlop one is around £300. The AMK can be from £400 to £600 depending on where you get it. It's only an hour tops to fit new one. My fault is actually a leaking air resavoir which is being replaced tomorrow. Hopefully it's all sorted then. New alternator.
Gearbox flush.
Post #570378 Mon Dec 03 2018 7:23pm
Plazmapete
Gearbox flush.
Post #570381 Mon Dec 03 2018 7:37pm
Stevepd
Well my Normal Height only stayed on, so it went into my indie yesterday and they have confirmed it needs a new compressor. They’re fitting a Hitachi one on Monday and fitting EGR blanks. The car only has 60k on it but is 12 years old.
Post #570669 Sat Dec 08 2018 8:44am
Plazmapete
Well after fitting the AMK compressor it's
Still the same. Turns out it was the air receiver tank that had a hole on it. All sorted. And the my original old compressor refitted. New alternator.
Gearbox flush.
Post #571167 Sun Dec 16 2018 9:52am
Pinnacle
Had this on mine for a few days, then when I went to start it one morning. I started to get gear box fault errors, this error, that error, not in park error etc.
Checked the battery and it was low, so I've removed it and fully charged and connected back up. No issues yet fingers crossed.
Post #574507 Mon Feb 04 2019 2:03pm
derekmines
Mine's gone all of sudden overnight.
Car has been fine (compressor's been a little louder than I would have expected for the last few weeks but nothing crazy)
This morning I set off to work and at the end of the street
"normal mode only" message appeared on the screen
By the time I got to work (an increasingly bouncy drive) the front end (both sides) was sat very low, the rear was fine though.
Would be strange for 2 airbags to fail at the same time I would have thought, and given the back still sits fine, I'm wondering if it's a block or a drier issue somehow.
my mechanic is going to have a look tomorrow though he's not a Range specialist so a fix might not be immediate
Post #583474 Wed Jul 03 2019 4:06pm
derekmines
C1A20 and C1A13 fault codes on mine today, Internet research not much help on this problem as there are so many possible causes to every symptom.
Need to now find a local LR specialist who can solve the actual problem not just throw parts at it.
Post #583508 Thu Jul 04 2019 10:04am
Eskimo
If it helps, I had the same fault codes on mine and the fix was a new Dunlop compressor from MM 4x4.
I did try one of the rebuild kits and while this worked for a few days the came back, but at least it meant i was out of access mode - not a nice drive home that night when it failed Laughing Laughing Laughing
Following the fault for the second time I tried to replace the exhaust and air delivery valves but in the process managed to shear off the M16 air delivery valve bolt which lead me to buying the new compressor as I needed the RRS back on the road ASAP.
I'm guessing it might be possible to drill out/extract the sheared bolt from the compressor housing and then fully rebuild it ready for when this fails.....
I chose not to upgrade to the AMK one as the cost was about twice as much as the replacement compressor and also the time involved in the necessary modifications, plus the £90.00 ECU re-program didn't make much sense, especially when you consider that the original Hitachi compressor appears to have not been touched since it was fitted.
Anyhoo enough ramblings from me and I hope it helps somehow Very Happy 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #583521 Thu Jul 04 2019 1:49pm
derekmines
Yep, local Landie specialist says new compressor time for me as well... in addition as the bracket holding the current AMK compressor is snapped I might as well upgrade to the newer type unit.... more $$ but a better quality product and longer term fix apparently.
Post #583571 Fri Jul 05 2019 11:10am
Bardley
Have a read on the Disco4 sister forum about compressors amd quality. There's a host of threads about rebuilds and air dryer service replacement etc.
The AMK is not an upgrade, just an alternative unit.
If a Hitachi was fitted originally and lasted many miles, then it stands to do the same again. They are a well made unit.
AMK have issues and are not a magical long lasting fix. Some D4 owners have fitted them and ended up paying twice because of quality problems. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #583606 Sat Jul 06 2019 6:02am
derekmines
So 2 weeks into the new compressor and issues again - same suspension failure orange triangle, joined tonight by a red triangle suspension failure max 30mph drive.
The garage who installed it have read codes and think it likely a faulty compressor, they're going to change it under warranty - hopefully that'll solve it!
Post #584808 Thu Aug 01 2019 6:37pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Who’s looking at it for you 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #584836 Thu Aug 01 2019 10:51pm
knwatkins
What compressor did they fit and what codes are they getting? Kev
Post #584843 Fri Aug 02 2019 6:54am
Page 2 of 3 <123>
