| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Suspension fault. Normal height only |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533    | Could you not get the codes read somewhere...give you a better idea   | ||
|  Sat Nov 17 2018 12:12pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | How old is your battery  | ||
|  Sat Nov 17 2018 3:20pm |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118      | Battery only 3 years old. Car starts first time every day. Have noticed it takes a while to raise to off road height somtimes. Also if car left for a couple of days the suspension has dropped. New alternator.
|  Sat Nov 17 2018 10:07pm |
| Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200      | Had exactly the same on mine with the warning a couple of months back. It happened sometimes after I had altered the ride height (rarely), and rear nearside corner would sit about 25mm lower than the rest after reversing. Would clear after switching off engine and restarting after a minute or so. Compressor fault, replaced under Marshall Warranty- worth every penny!! You can't see the eyes of the demon until him come callin' | ||
|  Sun Nov 18 2018 5:48pm |
| loadshifter Member Since: 04 Sep 2018 Location: COLCHESTER Posts: 6      | Had the same with mine turned out to be the compressor cost about me about £500 for a new one,if it is don't forget to renew the relay as well The careful overtaker avoids the undertaker ! | ||
|  Sun Nov 18 2018 6:02pm |
| Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16      | I had the same fault ,changed the battery and it disappeared until I put some leds in the stop and tail lights and it came back changed back to normal lamps no more faults ! | ||
|  Mon Nov 19 2018 6:06am |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118      | Had to buy new compressor. Didn't think £312 was too bad until the garage told me it didn't fit. The one they removed was an AMK compressor. The AMK compressor cost twice as much. F@#$ THAT. New alternator.
|  Fri Nov 23 2018 8:02pm |
| loadshifter Member Since: 04 Sep 2018 Location: COLCHESTER Posts: 6      | Glad your all sorted The careful overtaker avoids the undertaker ! | ||
|  Fri Nov 23 2018 10:13pm |
| Zeoman Member Since: 23 Sep 2017 Location: EH181DF Posts: 39      | Try here. Where I got mine a couple of weeks ago
|  Fri Nov 23 2018 10:18pm |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118      | Thanks I did see this.thort it was too good to be true.  Car not sorted yet. Not being done till Monday. New alternator.
|  Sat Nov 24 2018 7:55am |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118      | Well had the new AMK compressor fitted. Lasted 3 miles then the same fault came up. Any ideas???? It's going back in the garage tomorrow morning. New alternator.
|  Mon Nov 26 2018 5:31pm |
| Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262      | Everyone automatically assumes that the compressor is at fault. The light comes on ours every now and then and I thought that was the problem.
|  Sat Dec 01 2018 1:44pm |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480      | Not a bad idea. I tend to put mine in access height every time I park up just out of habit.
|  Sun Dec 02 2018 9:05am |
| Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178      | I got a suspension fault warning this morning...
|  Mon Dec 03 2018 11:43am |
| Posting Rules
