![]() | Home > General > ENGINE SYSTEM FAULT WARNING DISPLAY |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Removed |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 478 ![]() ![]() |
See if there is a Terraclean company near you that cleans the EGR's & DFP,
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
I had a Terraclean done on my Jag as it was showing EGR and DPF faults, it worked great. 2016 Black SDV8 Autobiography
ratty2828 Member Since: 07 Nov 2018 Location: southampton Posts: 12 ![]() ![]() ![]() |
Thanks for replies guys,took car to Terraclean garage today he said it wasn't the EGR VALVE but was the Turbo so don't know what to do now |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
not sure about the TDv8 but the V6's had some issues with the Turbo actuators sticking..
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
I had issues similar to this,, you don't say what mileage is on your car though. Normally EGR valves are not so much of a problem on the V8 compared to the V6, but saying that I suffered engine light and reduced performance issues at around the 95k mls mark. Had to replace the valve in question,, one thing I will say, if you have to replace them do both. I only replaced one and a couple of mouths later the other failed,, you will save money by doing both at once. 2010 RRS, TDV8
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
My TDV8 had the EGRs changed at over 150k miles and that was only because they had to come out to allow access to do something else - may as well change them in that situation! They weren't throwing any errors up to that point.
