Home > General > L320 3.0 - TDV6 vs SDV6
ramsden78
I have tried a search but I just came out more confused.. Obviously the SDV6 is the later engine but can anyone summarise issues for both or which is the better to go for?
I assume they all have their own issues including the 4.2 and 3.6?? What is the sweetspot for the L320s?
Post #569706 Sun Nov 25 2018 1:07pm
Tyrefitter
5.0sc is the one to have the least problems with,if you are wanting diesel I would go the the sdv8.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569709 Sun Nov 25 2018 1:19pm
no serious issues with the 4.2
Post #569710 Sun Nov 25 2018 1:24pm
for peace of mind and/or if you're doing low mileage: supercharged v8
if you really need to have a diesel, avoid the SDV6 and get the SDV8 Thumbs Up --
Post #569730 Sun Nov 25 2018 4:35pm
ramsden78
I wish I could afford a SDV8 😃
Post #569738 Sun Nov 25 2018 4:52pm
think of it this way: rather stretch your budget and get an SDV8 than get an SDV6 and then face a 10-15K repair bill when the crank breaks and LR walks away from any responsibility. --
Post #569767 Mon Nov 26 2018 6:21am
ramsden78
What am I missing? My budget is approx £15,000 and cheapest SDV8 around £35,000..
Post #569771 Mon Nov 26 2018 8:38am
Tim in Scotland
With that budget it would be the L320 TDv8 not an SDv8 as the TD was from 2007MY to 2010MY - there were some TDv8 2010 facelifted models but not many. TDv8 have their issues too - mostly turbo related and due to lack of care/maintenance by previous owners. TDv8 is a great car though if you can find a good one, they came only in HSE spec or HST with lots of toys on them that can also go wrong. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569778 Mon Nov 26 2018 11:27am
Brit Plumber
If the budget can stretch
http://vi.raptor.ebaydesc.com/ws/eBayISAPI...spheader=1
Doesn’t say if the Turbos have been done so probably not. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #569786 Mon Nov 26 2018 12:46pm
ramsden78
Thanks mate. If the diesels are all potentially ticking time bombs for crankshaft issues etc then I will look at petrol. 4.2 or 5.0.. If I was going to take a chance on a diesel it would be the SD v6 for the newer interior.
Post #569788 Mon Nov 26 2018 12:50pm
The diesels aren't all crankshaft time bombs, the TDV8 is a solid motor. I sold mine with 174k miles on it and it's still going as I bump in to the new owner in the pub now and then. And the newer interior can be had with a TDV8 lump up front.
The petrols are excellent so long as one doesn't do big miles or doesn't mind the fuel bills that come with big miles. 2012 SDV6 - it's missing a couple of cylinders
Post #569789 Mon Nov 26 2018 12:56pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
What’s this WHEN business?
It’s happened but it’s rare, very rare; however, when someone suffers the problem a lot of them appear of here for help and a bit of advice. That’s why when you read any forum you come to the conclusion that the product is a load of trouble - then you own 5 of them with no issues.
I do everything I can to mitigate problems by regular servicing etc, mostly oil because of oil dilution that affects loads of cars with a DPF, but I don’t lose sleep over it and neither should anyone else.
Post #569898 Tue Nov 27 2018 11:45am
Tyrefitter
Im lucky as im on my 6th sport & only had 2 minor issues,one being the park brake on my08 TDV8 & a suspension pump issue on my12 red edition both fixed under approved warranty,,BUT & a BIG but when I sold my14 AB SDV6 within 2 weeks of the new owner having it the crankshaft failed & LR Approved warranty wouldn't cover the cost of repair £18,500 plus vat for it fixing.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #569900 Tue Nov 27 2018 12:22pm
geoffsnook
Dont think it would make as much press if the engines were cheaper it's the fact as tyrefitter says upwards of £20,000 to have it repaired is what is hard to swallow Thumbs Up
Post #569902 Tue Nov 27 2018 12:47pm
ramsden78
Would crankshaft issues be covered by warranty? RAC, warrantywise etc
Post #570013 Wed Nov 28 2018 5:21pm
