![]() | Home > Maintenance & Modifications > 2010 RRS Start delay.. |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I also have 2010 and only had the car since Feb this year. Now the weather is getting colder here as well, I have had the same thing happening but I am just presuming it is the glow plugs taking longer to warm up. |
djb222 Member Since: 17 Apr 2018 Location: Birmingham Posts: 52 ![]() ![]() ![]() |
Thanks, I must say that did cross my mind. Must say overall I'm very pleased with the it so far. |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
This is what it should do. It’s the glow plugs doing their job. When you press the start button the delay is the initial warm up but after the engine cranks they continue for some time, even when the engine is running. If the glow plugs start acting up you will see white smoke on cranking and rough running for a while after start - if it starts.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I'm sure it is the glow plugs as mine does the same, is there something in the manual about it?
Thanks guys |
One more bit of info for interest is the the controlling factor in this is not the outside air temperature it’s the coolant temperature. Obviously in the morning after a night parked up they are probably quite close, but once the engine coolant is warm the delay reduces and eventually disappears. |
And from what I understand, the glow plugs come on when the ECU commands it and that could even be when warm and has been running for hours. All to do with emissions. 2019 5.0 SC SVA (Current)
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5103 ![]() ![]() ![]() |
yeah coolant temperature.
