Home > Technical > Auto wiper issue
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Auto wiper issue
Hi guys,
Had a new screen fitted a couple of weeks ago, it's a Range Rover original screen.
Noticed today that if I have the wipers in the auto position, when I start the car, it does a sweep even though the screen is clear. Never used to do that?
Any ideas.
Post #568964 Wed Nov 14 2018 6:49pm
the_big_1
It's a 2015 L495 by the way
Post #568965 Wed Nov 14 2018 6:56pm
don't they do that if dew is on the screen in the morning. and frost! which is rather a problem!
Post #568969 Wed Nov 14 2018 7:12pm
the_big_1
Tonight it's varnish and the screen was totally clear but still did it 🤔
Post #568971 Wed Nov 14 2018 7:18pm
syl
Don't you have to have everything recalibrated with a new screen (auto wipers, emergency braking, etc.)? RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #568984 Wed Nov 14 2018 10:27pm
the_big_1
I thought that was for if you have cameras for lane departure. Last time they changed the screen, it worked fine
Post #568986 Wed Nov 14 2018 10:34pm
Would appear sensor is self calibrating when first powered up.
The rain sensor must be re-authorized to a new windscreen, if fitted, or if transferred to another vehicle, the new
rain sensor assembly will automatically re-initialize when powered-up for the first time. In order for this to occur
successfully, it must be fitted and connected to the windscreen bracket.
Personally always switch auto off in Winter that way if blades frozen or stuck to screen it don't damage blades or possibly loosen arm on spline.
Post #568990 Wed Nov 14 2018 10:59pm
the_big_1
Hi Col,
Does that mean there is an issue with the fitment then as if it's auto calibrated, it's not calibrating correctly?
Post #568991 Wed Nov 14 2018 11:08pm
Hi, not sure on that one as that is just an extract from workshop manual, is it possible they damaged the sensor when removing it from old screen in anyway, may sound stupid but just a thought is there anything on the screen in front of sensor causing it, also does the light sensor work as believe that is integral in the same sensor.
Post #568992 Wed Nov 14 2018 11:16pm
the_big_1
Hi Col,
From memory the light sensor is under the mirror or that might be the main beam assist. I cleaned the screen on the outside yesterday but still did it. I was wondering if something like a finger print on the sensor or if the screen wasn't clean on the inside where the sensor is. Does the manual say how to remove / refit sensor?
Post #568994 Wed Nov 14 2018 11:24pm
If you pm me a email address I will try and send you a PDF of the section of the manual that details removing it.
Post #568995 Wed Nov 14 2018 11:34pm
the_big_1
I was thinking of removing it over the weekend, give the screen and sensor a good clean
Post #568997 Wed Nov 14 2018 11:39pm
Just remembered you can download manual from here, thanks to Naks
http://bit.ly/2iH7jgG
Post #568998 Wed Nov 14 2018 11:57pm
Tim in Scotland
L494 has a Winter park setting that will stop the wipers on top of the front screen heater element and is also the setting to use to avoid paintwork damage on the edge of the bonnet when lifting the wiper arms for replacing wiper blades. The problem with the winter park position is if you drive off with it set the wipers don’t park out at the bottom of the screen - something I would have thought is not out of the bounds of a technical cure - a small controller that basically checks that if Car is moving the wipers will drop to the normal parked position and return to the Winter park position when you switch off the engine. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569017 Thu Nov 15 2018 10:36am
