Home > Maintenance & Modifications > Driver side turbo replacement
richtdv8
United Kingdom 2008 Range Rover Sport TDV8 S Java Black
I have been looking at the excellent post by Boost re removing a turbo without lifting the body.
As I set about removing bits from my TDV8 I realised that the aforementioned post was for the passenger side turbo.
So far i have got the upper wishbone off, accessable heatshields out, bottom shields out and bottom crossmember out.
Hopefully in the next two days I will have the exhaust system out.
I'm in no rush with this job
So, has anyone out there managed to change out a drivers side turbo, without lifting the body.
Post #568876 Tue Nov 13 2018 3:30pm
richtdv8
Ok got the exhaust off, I was expecting oil in the exhaust and turbo but there was none and the turbo feels pretty free.
I know there is oil in the inlet side as ive had the flexible camera down the inlet pipe and it came back up covered in oil.
im guessing the oil seal has gone on the inlet side only, is this poss.
Post #568884 Tue Nov 13 2018 5:54pm
Didn't know you could remove the turbo on the V8 body on.
There will always be oil in the turbo inlet.
Drain it out the intercooler. Flush with petrol if you want.
Drive it for a month. Inspect intercooler pipes. If there is minimal oil, its fine
Post #568885 Tue Nov 13 2018 6:11pm
richtdv8
Cheers Andy,
There was a lot of white smoke coming out the exhaust and it happened very suddenly.
when I put the camera down the turbo inlet pipe it came out dripping with oil.
can oil get into the air inlet anywhere else apart from the turbo.
Post #568888 Tue Nov 13 2018 6:50pm
The driver's side turbo has the crankcase breather outlet plumbed in to its inlet pipe. The breather system has an oil separator in it (up in the V at the backend of the engine) that is supposed to remove oil but no doubt some will get through.
http://www.rrsport.co.uk/gallery/albums/us...20PCVt.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #568896 Tue Nov 13 2018 8:28pm
Isnt there a mod, factory tsb fix to sort this?
Smoke from both exhausts?
Post #568911 Tue Nov 13 2018 9:44pm
I thought that was for a TDV6 issue. 2012 SDV6 - it's missing a couple of cylinders
Post #568913 Tue Nov 13 2018 10:04pm
richtdv8
Thanks for the info, I hope that is the problem as it would save me removing the turbo, which may not be poss anyway.
i will take off the pipe and have a look.
what can go wrong with the crankcase breather system that would cause a large amount of oil to be dunped into the air inlet.
Post #568914 Tue Nov 13 2018 10:39pm
