Home > Faults & Fixes > Range Rover Sport 2.7 tdv6 white smoke on start
roksegs
Slovenia 2006 Range Rover Sport TDV6 HSE Java Black
Helo all,
i have trouble with my Range rover sport 2.7 tdv6. i post video if anyone of u have idea what is wrong with my car.
Injectors was all checked and they are ok. i dont have compresion on 1st cylinder. I have alot of white smoke when i start engine after engine got worm no smoke anymore. But i hear some chuckling in engine.
one mechanic guy say this is the problem with camshafts (wrong timing) but i dont think so.
i will be really happy if someone can tell me or if someone have same problem,...
https://vimeo.com/300266002
Post #568830 Tue Nov 13 2018 7:36am
garrycol
Australia
I am glad you took my advice and came across to this forum with your issue.
The Americans mainly have V8 petrols and no diesels so do not know much about them.
If people here have a look at your video I am sure the experts will be able to help.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #568840 Tue Nov 13 2018 10:17am
roksegs
i hope so and thanks u very much for advice me to write my post here.
Post #568841 Tue Nov 13 2018 10:22am
Brit Plumber
I’m no expert but if you don’t have compression on no 1 cylinder, the white smoke is probably the vaporised diesal that hasn’t been used during the no 1 compression cycle being pushed out of the cylinder and mixing with the hot exhaust gas from the other 5 cylinders. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #568844 Tue Nov 13 2018 10:43am
roksegs
maybe somebody else may give some opinion
Post #569022 Thu Nov 15 2018 2:41pm
Brit Plumber
I’d be more concerned with the issue of no compression on no.1 cylinder, that’s youre issue. 2019 5.0 SC SVA (Current)
Post #569025 Thu Nov 15 2018 3:37pm
roksegs
what about this chuckling in engine wich can u hear in video.
Can be this sound becouse of damaged camshaft ???
Post #569064 Fri Nov 16 2018 9:33am
garrycol
Australia
The sound and the lack of engine compression is clearly related. What was going on when the noise started? How do you know you have low compression.
It is time to initially look at the valve gear on that side of the engine and go from there.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #569066 Fri Nov 16 2018 10:27am
Brit Plumber
If you think of what cylinder 1 is doing, the piston is trying to compress about 450cc of air into a small gap. If you don’t have compression it’s because there is a gap that air is escaping through. The exhaust valve will open and let out the uncompressed air and fuel mixture on the exhaust stroke. Depending on where the air goes on the compression cycle will have an effect on noise and damage to the engine. You could end up with fuel in the oil, over pressure of the cooling system, water in the oil etc. Etc. Hopefully it’s a cylinder head gasket and not a warped/cracked head. I’m convinced if you fix the misfire, the noise and white smoke will be gone. 2019 5.0 SC SVA (Current)
Post #569067 Fri Nov 16 2018 10:33am
roksegs
Its start like that to car make white smoke just on start at evening, after 10-15 sec he run normal without any smoke or any clunking sound in motor. After 5 days i just going home and i start hearing this clunking sound in the motor,...
I drive my car to mechanic guys and he test compresion on first Cylinder. After that mechaning guys said i have problem with the camshaft,... becouse of that im asking here if some1 have same problem,... i dont want spend alot of money for nothing Sad
Im sry for my bad english Smile i hope u all understand me
Post #569070 Fri Nov 16 2018 11:02am
Brit Plumber
Anyone know if the 2.7 has variable cams? I wonder if the mechanic suspects the variable cams seized. 2019 5.0 SC SVA (Current)
Post #569088 Fri Nov 16 2018 6:37pm
