![]() | Home > General (L494) > Battery issue |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
I have just purchased an approved used Sport, 2 and a half years old, and they have fitted a new battery as part of there 165point check, if that helps? |
HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81 ![]() ![]() |
Interesting thanks. I’ll mention it. Looks like it had new tyres and brakes before it was sold anyway. Easily £2k worth there! MY15.5 HSE - SDV6 - Santorini Black |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
The original battery is an Exide battery. I got one (Exide) recently from Euro car parts. I have just looked & the battery is £320 but use code Winter35 at checkout which gives you 35% off (£112) so battery is £320- £112=£208
Update... car away back to the dealership for the second time in 5 months.. MY15.5 HSE - SDV6 - Santorini Black |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
Are you running any type of dashcam? Couldn’t believe the draw they actually take out of a battery! Mine caused all sorts of flat battery issues before changing it!
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I have the Thinkware dashcam which has a setting in the menu which shuts it down once the car battery falls below a certain voltage, which you can pre-set. If you do have a dashcam, as suggested, it's worth checking the settings before binning it. |
Well actually it’s interesting you mention that, because I do intend to have Thinkware front and rear cams fitted in the next couple of weeks. At the minute though nothing aftermarket on it. MY15.5 HSE - SDV6 - Santorini Black |
Battery issue turned out to be an O2 sensor (no idea) and the fuel slosh problem is not covered by the extended warranty as it’s a known problem (can’t figure that out either) but they’re going down “other avenues” to fix it and it’s a big job. So I got a new discovery in the meantime, which is no RR Sport !! And who on earth decided to put a 2 litre 4 cylinder in one ?? MY15.5 HSE - SDV6 - Santorini Black |
