![]() | Home > Faults & Fixes > Red battery light |
Mine comes on every time I stop the car,I think it’s something to do with the dash cam as it’s ever since I fitted it & it did the same in my other L494.Even if I leave on charge all day the day after the light appears again also if I give it a 3-4 hour run as soon as I stop the car the light appears,I think it’s only the small battery for the stop start in the rear that’s causing the problem as I’ve never had a problem starting the car.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Most likely a failed alternator. 07MY RRS TDV6
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
The battery had 12.1 volts before starting this morning. It was 13.48 for the first two minutes all ok and then there was a whining noise from alternator I assume and voltage was 13.05 and dropping..
Strange that the alternator would fail as soon as I charged the battery. Its goin in on Thurs anyway. I have a funny feeling its the battery. I don't know why tho. |
Well I have just had it running for 20min on the drive. The voltage across the battery showed 12.1 V. After a while there were all sorts of bongs from the dash and all the warnings came on - I assume these were because the battery was only at 11.8v by then. I stopped it but it restarted no probs. I've got the battery on charge again as I need to drive it to the garage on Thurs. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
I would expect to see 14.4V or thereabouts if the alternator was performing correctly,, even if the battery was duff. The car won't run for very long if the battery is not getting any charge 2010 RRS, TDV8
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
12.1 volts indicates around 45% charge. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
That is symptomatic of a failed alternator - I had this earlier this year - will generate power sometimes but not all the time - dash lights and gongs. Car would still start and move but all sorts of failures. 07MY RRS TDV6 Arctic Frost Aspen Interior |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9121 ![]() ![]() ![]() |
If it only had 12.1V across it with the engine running then the alternator is ![]() 2008 TDV8 - it was a labour of love and is much missed |
Twas a failure of the alternator. Purely coincidental. Cost £500.. Im not putting a battery charger on it ever again..
You can disable the function on the dashboard menu 2010 RRS, TDV8
Was nothing to do with a battery charger - there are no issues with putting on a charger with the battery in the car if it is done correctly. +ive on the +ive side of the battery and -ive on the earthing post near the battery, not on the -ive post of the battery. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Yeah well I won't trust it again.. Ive been doing it for years and never had a problem before. Next time I will just buy a new battery its cheaper.. |
