Home > Technical > RR sport 2009 rear suspension clu
Demaske1
United Kingdom 2009 Range Rover Sport TDV8 HSE Arctic Frost
I have just purchased a 50,000 miles full dealers history sport 3.6 td hse. It’s had new discs and pads all round. New front wheels bearings and new prop shaft. The problem is a slight clunk from the rear when going over the occasional bump. It happens over 20 mph and isn’t severe just annoying. We defiantly think it’s from the rear. Any help or common issue that I can check for whilst under the car or does it have to be jacked up to check. It’s super quiet apart from that ! Is there a common part to look at. Thanks.
Post #567775 Sat Oct 27 2018 9:03pm
Brit Plumber
Cant answer your question mate but just be aware that if you go under the car, the suspension can be active for hours after ignition off and can re-level itself with out warning and any time. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567776 Sat Oct 27 2018 9:24pm
Camelrock
I would start by looking at the arb bushes and links 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #567778 Sat Oct 27 2018 11:52pm
Demaske1
still clunking !!!!!!!!!!!!
so the car has now been to a suspension specialists. I asked them to check anti roll bar bushes and they said it wasn't those it was the bottom arms and they don't replace the arms just the bushes with better ones. That job has been done and even though quieter there is the odd clunk still. They now believe there is a stop on the sway bar and is occasionally hitting the side of the chassis and this is caused by the anti roll bar bushes letting the bar move from side to side occasionally causing the knock.
They are now intending packing the sway bar with small tile like squares which is a Landrover part issued by Landrover as they were no longer doing warranty claims on anti roll bar bushes. Drop links have also been done and everything else on the car appears tight as it should be. Does anyone else know anything about this sway bar moving occasionally from side to side ?
Post #570092 Thu Nov 29 2018 3:20pm
The bar does have lateral movement in it as that's how it works. Shimming the ARB bushes is a known solution. 2012 SDV6 - it's missing a couple of cylinders
Post #570100 Thu Nov 29 2018 6:17pm
