![]() | Home > Technical > Range Rover Sport 2011 DRL fitment |
| jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207
I want to fit some DRL lights to my 2011 RRS, does anybody know if there is an ignition on/off connection in the fuse box I can use?
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Pin 19 on connector CO582 (the one that plugs into the front of the fuse box) and change fuse 58 for a 3 amp.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
I used Fuse 52 but I think Fuse 54 is also a Ignition Live in the passengers footwell fuse box, if you have AFS headlights you could use Pin No. 14 in the headlamp plugs, Red wire with Orange tracer R/H headlight, Red wire with Black tracer L/H headlight. Or you could use Drivers seat heater relay R1 red wire in engine compartment fuse box. I have previously used all three for ignition lives with no problems.
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975
It looks like you have the info you need above. But I’ll just chip in with this link. It’s an example of one of several DRL products they supply and their site does host some diagrams and fitting information if you poke around.
You could also consider the Land Rover original DRLs for the L320 as well. 2019 5.0 SC SVA (Current)
Genuine L/R ones are at least now down to £200.00 a set, used to be priced at a ridiculous £400.00 + a set, which would probably explain why nobody bought them then.
Cols right, I bought mine for a fraction under £200 on special offer. 2019 5.0 SC SVA (Current)
If you Google VPLSV0065 (A/B bumper Kit) or VPLSV0064 (HSE/SE bumper Kit) might turn something up on the likes ebay. The only thing is some of the after market kits just dim the DRL's when dipped/main beam headlights are switched on, where as I'm not sure but I think the L/R one's turn off completely, although I imagine this could be overcome with some sort of relay or controller unit.
Yes the Land Rover ones turn off when the side lights are turned on. I was thinking of changing mine to turn off when the main turn on. 2019 5.0 SC SVA (Current)
If I remember right, I think the controller on mine is wired to pin 11 dipped headlights so they dim when dip/main are on, also when switch is in auto position.
I now have my DRL light strips I want to fit.
Finally found a DRL strip to fit that would also be bright enough during the day as some are to dull.
| Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479
Looks very neat,
Thanks, that’s exactly what I was trying to achieve |
| All times are GMT |
