![]() | Home > General > 2011 tdv6 won't start trying to crank and dies. |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
You'll pay way more than 3k for an engine supplied and fitted. Really hope it isn't that. 2 new turbos supplied and fitted was near 4k at an indy specialist, never mind main dealer. |
| newlove2003 Member Since: 16 Apr 2015 Location: west yorkshire Posts: 24
Hiya the video is here any help would be great also just cleared all the faults and the diesel a control, code P0627
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Fuel pump issue, at least it not the crank.
Agreed, its a fuelling issue.
Thanks for the speedy reply, feel like a ton as been lifted off of me, independent range rover speacialst scared the living |
If it’s not been serviced in a long time, download the check sheet from topix (there maybe a copy on the site in someone’s profile) and ask him to perform all the checks and fluid changes. Also ask him to check the fuel pump relay and if he can, check for fuel pressure from the pump. I suspect you may need a new pump and relay. 2019 5.0 SC SVA (Current)
Will do thank you, well my mate couldn't make it he had to do somthing with his bird, so I've had a little look and seen 2 videos on changing the fuel filter doesn't look hard at all, looks very simple would to be possible that I could do this myself? Also could it be possible the reason it ain't working is down to the wiring on the fuel filter? Thank you. |
I don’t think the filter will have any wiring but it would be worth replacing if it hasn’t been serviced in a long time. If you mean fuel pump, I think there may be 2, one in the tank and one else where. The one in the tank is bound to be a PITA, because of where it is and how to get to it.
| paulwest16 Member Since: 19 Feb 2023 Location: Essex Posts: 5
Did you ever solve this problem and if so what was the outcome.
| RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6
@paulwest16
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153
The original post is 5 years old, I think it unlikely you will get a response now from the O.P, but you may be lucky.
Mine was the chain on the inlet on the passenger side broke. It a small chain that does the inlet cam not the main one that goes to the crank that’s why the engine was spinning ok still. |
Hi Paul, thanks so much for your reply. I suppose a broken cam chain is better than a broken crank!!
Thanks Col |
