Home > Technical > R,R,S. FUEL BURNING HEATER
John r
United Kingdom 2006 Range Rover Sport TDV6 HSE Siberian Silver
Hi hope some one can help I recently bought a RRS. 2006 and due to being disabled I want to fit a remote control to my webasto heater so I don't need to sit in a cold car while it warms up can any one help
I need to which wire or wires to conect and where to find then many thanks. jr
Post #567430 Mon Oct 22 2018 10:55am
well you need to buy a kit. I think BAS sell them.
Also can find them on ebay.
The basic kit will use the LR button on key (configured to headlight mode) to turn it on.
Advanced kits are activated by mobile phone txt
Post #567435 Mon Oct 22 2018 12:03pm
Buckster
Guy called Bodsy on here sell and fits the kits, top man too Thumbs Up
http://www.rrsport.co.uk/forum/topic43755.html?highlight=bodsy 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #567439 Mon Oct 22 2018 12:56pm
John r
Thanks for you information
Would you know if there is wiring in the car for a remote reciever even if the receiver is not fitted
Post #567443 Mon Oct 22 2018 2:04pm
not on your age RRS
I think the big RR had it
Post #567458 Mon Oct 22 2018 5:22pm
John r
Thanks Andy
Would you know if there is a wire I can tap into to put a switch to start the heater
Post #567463 Mon Oct 22 2018 6:16pm
You can’t just connect a wire to start the heater.
You can get a £40 item off eBay to do it
Post #567471 Mon Oct 22 2018 7:01pm
Bodsy
Site Sponsor
John,
I supply the Altox heater kits for the FBH, this allows you to use your phone to activate the fuel burning heater so it heats the water up around the engine/heater matrix.
Your year car may or may not have the trigger wire on the FBH. It’s. W-bus signal, so it’s not as straight forward as putting 12v through it.
I’m not far from you if you wanted one fitting. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #567484 Mon Oct 22 2018 11:02pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
How much is one of those kits supplied and fitted (to West Mids for example as working thee at the mo) ? 2012 MY SDV6.
Post #567499 Tue Oct 23 2018 8:09am
Rickster
Hi Bodsy,
Are you coming near Essex as im still interested in having one of these kits fitted?
Rick
Post #567510 Tue Oct 23 2018 11:56am
HughN
Wales
Hi Andy,
What do I needed to search for on eBay. There are used telestart units from the L322 and a few expensive after-market kits. The CAN-bus requirement makes it a pain, otherwise a wi-fi switch would suffice?
Thanks,
Hugh
Post #567883 Tue Oct 30 2018 10:07am
https://rover.ebay.com/rover/0/0/0?mpre=ht...2590138547
W-bus analog heater
In Europe
Post #567897 Tue Oct 30 2018 1:08pm
HughN
Wales
Marvellous - thanks Andy!
Post #567901 Tue Oct 30 2018 1:36pm
