Home > In Car Electronics > Back Passenger door locking
imccarrison
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Hi All,
My back passenger door doesn't unlock and i have to open the passenger front door and reach in to unlock.
I have keyless entry
Any suggestion. Was hoping there would be an easy fix you will in need to replace the lock.
2012 Sport sdv6
Thanks
Post #567329 Sat Oct 20 2018 4:27pm
Disco_Mikey
Nope, needs a new lock assembly
Post #567330 Sat Oct 20 2018 5:11pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Is it expensive or complex to fix ? My passenger side rear door occasionally refuses to unlock. Thought it was child lock issue at first but isn't.
Post #567364 Sun Oct 21 2018 10:07am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
It's not especially expensive, the lock mechanism is about £80 iirc. But balance that against if it fails completely, it is almost impossible to get the trim off, with the door closed. Then you really are a bit stuffed Big Cry
Like most people, I left is quite a while before I got around to fixing it. By then it would only unlock very occasionally. It took about half a hour of swearing and jiggling before it unlocked. Thumbs Up
Post #568632 Fri Nov 09 2018 6:12pm
