![]() | Home > General (L494) > LOADSPACE RETENTION KIT |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210 ![]() ![]() ![]() |
here's a cheaper solution:
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
You obviously have too much spare time on your hands |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586 ![]() ![]() |
Rails here:-
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
Looking at the fitting instructions, you remove the existing lashing points and what would appear to be narrow bits of carpet running length ways between them and bin them, the new rail kit should come complete with rails and new lashing eye's. The rails fit where the carpet strips were removed and secured using original lashing eye mounting points and a couple of new support brackets in the center of each rail which are also supplied in the kit.
Thanks for that Col, that's what I wasn't sure about |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
I purchased two of these and they really do work except for really heavy items - keep suitcases in place for example.
