![]() | Home > Technical > AFS Both lights are pointing down. |
Test that left motor and fix that issue first. It may just sort the lost signal on the right. 2019 5.0 SC SVA (Current)
pelle Member Since: 01 Jan 2014 Location: Sigtuna Posts: 49 ![]() ![]() |
Ok, but how du mean I can test the motor? |
I have solved the right lamp, it was probably a bad connection in the socket or the wiring behind.
