![]() | Home > Faults & Fixes > RRS 3.6 V8 2008 Clunking noise rear |
Hard to say bud but it sounds like the bushes have been checked/replaced and if everything else is tight, I can only think your ARB needs bleeding or replaced. Does it look like any part of the dynamic response system has had work done? 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
Wouldn't be something simple like the n/s/r harmonic damper (big swinging lump of metal attached to chassis) just touching the chassis or exhaust when pulling away.
Dslancs Member Since: 10 Oct 2018 Location: Lancashire Posts: 8 ![]() ![]() ![]() |
Dynamic response system ? Sorry pal way over my head like I said I know nothing about cars suppose I need to read up on this stuff. Just disappointed with the specialists not finding the problem when they had it so long. The specialist heard the noise the 1st time he looked at it so can't understand just want it bottoming
Thanks col
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
Does it happen even with the most gentle of starts or just when a bit of right foot is used? I'm wondering if the harmonic mass damper is hitting something when you pull away sharply. This is one of a pair of big lumps of cast steel that sit over the rear chassis members above the tail pipes each side of the car. It is free to move in a rocking direction front to rear. If this is moving under acceleration then it might be just knocking against the rear exhaust box or something else (not much there to hit but it's not unknown). Worth a look - you can do it on your drive. Wear some goggles if you've going to have a look as it will likely drop crud in your face when you're under the back. You can see the weight and move it easily by hand. Try it through its full range of movement to see if it touches anything. Two minutes to check and totally free. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I take it the rear prop shaft centre bearing has been checked, big rubber donut with the prop shaft running through the middle. The rubber separates from the outer bearing allowing the prop shaft to bang up and down . Easy to check by looking under the car, may have to remove a sheild. |
Hi
Guys an update on my issue.my independent specialist drained the rear diff and refilled twice which I'm pleased to say seems to have cleared the clunking noise.although a few days later I get the 3 amigos on the dash and HDC fault transmission fault special programs off suspension lowered !! Error codes are P0806 & P080a clutch position not learnt he's tried to update the rear diff but them 2 error codes remain any ideas ?? But hey the clunks gone !!! My Swede is mashed only had the car 4 months |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 478 ![]() ![]() |
I may be completely wrong but here goes anyway,
You say he "reset" the rear diff. Was that a calibration of the diff actuator or just clearing the codes?
Hi thanks for replying
The two error codes you quoted appear tp relate to the rear diff actuator. I'm not aware why a failed brake switch will throw up those codes.
Hi
I assume they refer to the motor that drives the internals. It's bolted to the outside of the diff with 4 bolts plus a loom connector. The internals are mechanical - two arms driving a ball ramp that presses the clutch plates together to give the locking action. 2012 SDV6 - it's missing a couple of cylinders
