![]() | Home > General > Non OEM brakes & Extended Warranty |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 929 ![]() ![]() |
Ask the main dealer the question. This is not for someone else to have a guess at. Also check what is covered as the extended warranty is not the same as the manufacturers warranty. Some things are not covered. |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
All the dealer will say is "all claims will be rejected" as they will want the business; I was hoping others may have been in a similar situation before & I might benefit from their experiences. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5101 ![]() ![]() ![]() |
Would have thought it highly unlikely discs and pads would be covered under warranty anyway as these would be considered wear and tear items, mind you L/R might use it as a excuse if there was a problem with another part of the brake system.
Looks like you have your answer "all claims will be rejected" after all, its them who you will have to take the car back to for warranty |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5100 ![]() ![]() ![]() |
Does it really need new discs! What mileage has it done? |
44,000 miles; I have just checked the discs and all four have a lip on the outer edge - perhaps 1-2mm - so presume they do need changing. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9095 ![]() ![]() ![]() |
It won't affect the warranty because brake pads and dsics are covered by it anyway. The calipers are but the make of pad / disc won't affect these anyway. 2012 SDV6 - it's missing a couple of cylinders
