Home > Technical > CFF edit fails
Gandalf
CFF edit fails
Hi all been trying to edit my cff file but the edits fail every time Big Cry and I get a load of faults flash up on the dash, turn the ignition off then back on faults clear but no edits implemented. 2005 RRS 2.7 HSE. is this normal.
Peter If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #566141 Mon Oct 01 2018 6:43pm
Bardley
Is your battery up on volts?
Recommendation is to have an external source connected to secure the level while you're making changes.
Def. pressing the correct buttons on the software?
Upload change/yes etc...
Just stating the obvious and sure you have already checked. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #566143 Mon Oct 01 2018 6:55pm
Gandalf
reading was 11.9v on the dash which it's always done batteries only about 5 months old Bosch If it ain't broken down it soon will
Post #566144 Mon Oct 01 2018 7:07pm
Bardley
Just thinking that the GAP unit will abort the change if battery is low.
That is low voltage.. amd was likely showing in RED at the top of the dispay?
Try again with maybe a second bttery connected? 2011 MY D4 HSE
Post #566145 Mon Oct 01 2018 7:16pm
Gandalf
Could be that spent all day sorting a load of electrical gremlins so battery might have been a bit low. will give it another go tomorrow. If it ain't broken down it soon will
Post #566150 Mon Oct 01 2018 9:07pm
scarey
do the ccf edits whilst the engine is running....
Post #566164 Tue Oct 02 2018 7:45am
have you actually tried that ?
Post #566170 Tue Oct 02 2018 11:01am
Gandalf
Tried that but tells you to switch engine off. Anyway had another go voltage in green 12.5v.
ecu flash Thumbs Up
clock in dash Thumbs Up
drls Thumbs Up
camera Thumbs Up
parking brake key out apply Censored get a load of fault messages but clear after I switch off and back on, Not really bothered just me being lazy as I'm always forgetting to apply the brake when parked up If it ain't broken down it soon will
Post #566171 Tue Oct 02 2018 12:27pm
scarey
i'm surprised that it tells you to switch the engine off, never happened to me...
Post #566172 Tue Oct 02 2018 12:44pm
out of interest, what has enabling DRLs done ?
What headlights have you got
Post #566187 Tue Oct 02 2018 7:24pm
Gandalf
I have it set to Scandinavian if light switch is either off or auto when you start the engine the side head and tail lights come on but if you switch to side lights or head lights they behave as normal. Weird that I can edit other functions but not the parking brake options Confused If it ain't broken down it soon will
Post #566198 Tue Oct 02 2018 8:20pm
Oh daytime lights. I see
Post #566205 Tue Oct 02 2018 9:05pm
