Home > Tips & Tricks > Sorted - RRS subwoofer shake. |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Thanks for the tip, I'll have to give this a try as the rattle just makes what is 'supposed to be' a premium sound system just sound so cheap. I've just turned the bass down.
Sun Sep 23 2018 12:07pm |
Yes, exactly that. The mat was large tufted from Matalan for a fiver. Helps to absorb rearward soundwaves. You could also use a bit of loft insulation. It may be fine without. Try without it first and keep trim off, it only takes 5 mins to spin out the sub and drop a mat in and then retighten. When you are happy just pop the trim back on.
Sun Sep 23 2018 1:01pm |
Thanks, I'll give it a go
Sun Sep 23 2018 9:35pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Nice one, next job for me. Been neglecting the RRS of late due to attention directed towards used motorhome purchase and a few issues it had.
Sun Sep 23 2018 10:18pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
Have you got a pic of the finish on the job? |
Sun Sep 23 2018 10:23pm |
Good stuff. Let me know how you both get on. I probably went a bit ott but a bit of dampening on the back of the plastic trim and bare metal, as well as behind the sub wont hurt. The plastic is quite flexible. |
Sun Sep 23 2018 10:31pm |
Sun Sep 23 2018 10:35pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Our 2005 RRSS has a subwoofer rattle too. Is it located in the same place? When I say rattle I mean the sound distorts.. |
Tue Sep 25 2018 6:35am |
It is in the same place as far as I know on all RRS 1 models. If you have the problem of not being able to have any volume or real bass give it a try. There is nothing wrong with the driver/speaker itself just the absence of proper dampening. |
Tue Sep 25 2018 8:26am |
my RRS is going in to the audio shop again tomorrow.
Wed Nov 14 2018 2:51pm |
also the window controller was replaced few weeks ago and now at times the seat memory buttons rattle aswell does the door card need to come off again? I think something may be in the way |
Wed Nov 14 2018 2:52pm |
Deadening the trim isn't enough of itself. The problem is exacerbated as there is nothing in the way of deadening or dampening behind the actual sub itself. My solution was dampening behind the driver, then on exposed metalwork that you see with trim removed, and on the back of the actual trim as it is low rent flexing plastic.
Wed Nov 14 2018 4:40pm |
