Home > General > Rear timing belt
Iggy
United Kingdom 2011 Range Rover Sport SDV6 HSE Santorini Black
Rear timing belt
Hi all any help would be appreciated.
Crank is locked.
Camshaft pins are in.
I am changing the rear timing belt and can't seem to get the location pin in to lock the fuel pump tool to the engine.
I have tapered the end of the pin to make it easier I am in the right location and have tried moving the drive sprocket which only moves 5mm in either direction before touching the casing.
What's the chances of the tool being faulty.
Post #565790 Mon Sep 24 2018 10:12am
