Home > General > 2006 RRSport alternator help !!!!
jfleet84
My guys I’d like your opinion.
I could hear a whine noise from one of my pulleys then a red battery light came on along with a smell of rubber. So I stripped it down and replaced the alternator. Mine has the anti roll bar pump which added to the pain of changing the alternator. While it was stripped I span all the pulleys and they all seemed loose apart from the Anti-Roll bar pump. It wasn’t horrendous just not as free as all the others. Are these many to be like this or should they be totally free?? So I then fitted the new alternator and built it back up. When started I was met with a squeak noise So I replaced the drive belt but it was still there. I took it for a test drive and the sqeak goes away after 2 mins of driving. However today the red battery light came back on today. Could it be the Anti-Roll bar pulley somehow doing this ?? Or do you guys think I’ve fitted a duff alternator ??? With the new alternator the battery is recieving14.1 volts if that helps.
Any help or opinions would be great !!!
Post #565684 Sat Sep 22 2018 11:04am
what make was the alternator ?
Where did you get it from ?
These are fussy about their alternators
Post #565685 Sat Sep 22 2018 11:08am
jfleet84
It was a RTX one from eurocarparts.
Post #565686 Sat Sep 22 2018 11:17am
The advise on here is to only fit Denso alternators
with a lot of evidence to support this.
Try and return for a refund if the battery light is on
Post #565688 Sat Sep 22 2018 11:40am
jfleet84
Ah ok. I’ll give the denso ago. Cheers for the advise !!!!
Post #565689 Sat Sep 22 2018 12:29pm
You may also want to check the 5A ALT fuse in the box next to the battery
Just in case it’s simple
Post #565695 Sat Sep 22 2018 2:23pm
jfleet84
Just checked all the 5a fuses. They all seem ok. Must be a dud alternator. Fingers crossed or I’m lost !! 😐
Post #565696 Sat Sep 22 2018 2:34pm
geoffsnook
Some eurocarparts are absolute c!!p you are better off with a denso Thumbs Up
Post #565705 Sat Sep 22 2018 6:47pm
