Home > My Range Rover Sport > Soon to be an owner.
Page 1 of 3 123>
Autobiography1969
I am collecting my new to me;
2012 Range Rover Sport Autobiography in early October,
I have always thought they were stunning from that first moment I
saw the early one in orange, I am a little older now and am lucky to
be able to get the one I really want..
I have a nearly 500 mile test drive home so I should know if there are any issues.
But can anyone give some advise on what I should check before I hand over my
hard earned money and drive her home?
Thank you in advance..
Post #565399 Tue Sep 18 2018 10:41pm
Brit Plumber
What engine is it? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #565401 Wed Sep 19 2018 6:43am
Autobiography1969
It's the 256hp 442 lbs-ft torque
3.0 SDV6..
Post #565407 Wed Sep 19 2018 8:32am
PEACHY
Welcome - any pics or links to your new purchase ? Thumbs Up 16MY Estoril Blue SVR.............
Post #565409 Wed Sep 19 2018 8:56am
Autobiography1969
I will put a couple of pic's up tonight, but the seller has removed all advertising so no links..
It's Indus Silver, full grey and black leather, piano black trim, black roof lining, 22" style 7 wheels.
39,509 miles, fdsh..
I can't wait..
Post #565411 Wed Sep 19 2018 9:17am
Re: Soon to be an owner.
Have a good look at the wheels for cracks etc., if they are 22" style Seven they are copies as L/R never fitted 22" rims to the L320.
Post #565412 Wed Sep 19 2018 9:51am
Autobiography1969
Good spot, I know that they are brand new wheels and tyres, but I will ask them where they come from and if they are OEM, but for the newer model, or replica ones,
Thanks...
Post #565413 Wed Sep 19 2018 10:04am
LeeRRS
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Siberian Silver
check the suspension very closely. take it for a good run, then get under it and check for fluid leaks. 2012 Range Rover Sport Autobiography 3.0 SDV6
2011 VW Golf 1.4 TSI Blue
2001 Yamaha YZFR1 Blue, my pride and joy
2007 Subaru Impreza STI 300 BHP Gone and missed
Post #565434 Wed Sep 19 2018 12:42pm
Autobiography1969
Thanks Lee,
The list is growing..
Post #565441 Wed Sep 19 2018 1:00pm
LeeRRS
no problem
dealers often spray break cleaner on the suspension to clean off the oil leak. so it's really important to take it for a good ride before checking. any sign of a leak, run a mile or negotiate the price accordingly. 2012 Range Rover Sport Autobiography 3.0 SDV6
Post #565443 Wed Sep 19 2018 1:04pm
Tim in Scotland
Test the high /low transfer box change over works smoothly and quietly - start the engine, select N, open driver’s window, press Hi/lo button and the change should occur......... or not if the car has not been used properly. Check the indication lights illuminate on the dash and in the 4x4 info screen then shift it back to high ratio. It isn’t a huge issue to fix, it just shows the previous owners never maintained the car according to the manual, it is a negotiating point if it doesn’t shift in and out smoothly and quietly, you are buying a hugely capable off road vehicle,even if you don’t intend to go further offroad than the golf club car park all the off road bits should still work properly.
Col’s point about 22” wheels is especially important as the steering rack was not designed originally to take bigger wheels than 19” and then a heavy duty rack was made standard in about 2007 and all RRS’s could then take up to 20” wheels but nothing bigger. Also Insurance can be an issue with non OEM wheels bigger than the car is designed to have.... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #565448 Wed Sep 19 2018 2:51pm
Autobiography1969
Hi Tim,
Thanks for that, noted and on the list..
Wheels for Manufacturer, and make sure they are brand new not used cracked,
Steering for stiffness and noise,
Underside for leaks front to back,
Hill decent,
Hi low ratio,
Air suspension height adjustment,
Oil level and colour,
Coolant and colour,
Gears change seamlessly,
All switches buttons work,
Spare wheel,
Memory seats,
Anything else??
Post #565452 Wed Sep 19 2018 3:07pm
Bill Portland
fob for remote climate control(heating and cooling)
electric parking brake operation Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #565453 Wed Sep 19 2018 4:23pm
Tim in Scotland
Check the climate control cools as well as heats - there is no need to switch it off, just leave it in auto but there are a lot of misguided people out there who think running it all year round consumes extra fuel, it doesn’t these days now systems are more efficient. You do more damage to electronics switching it off because the dehumidifier doesn’t run when the climate is switched off, it works regardless of whether you have a warmer or a colder temperature set. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #565457 Wed Sep 19 2018 5:03pm
Bill Portland
Are you sure about that Tim? I certainly notice a drop in mpg when I have the Aircon on. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #565458 Wed Sep 19 2018 5:45pm
Page 1 of 3 123>
