![]() | Home > Faults & Fixes > key fob flat after 4 days |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Definitely not normal!
Sounds as if your fob rechargeable battery has reached the end of its life so is no longer holding a charge. You can buy the battery on eBay and change it yourself but it is quite tricky to open the fob case without damaging it or yourself and you need a soldering iron and superglue. Search this forum and the Disco 3 forum and you'll find a few very helpful 'how to' threads.
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 ![]() ![]() ![]() |
i have a new battery n case fitted but still goes flat ?? |
hi paddy. nice to hear from you hope all is well.
All good here thanks. Sorry to hear the problem is persisting. I don't recall anyone ever reporting failure of the charging system. Suppose very short journeys would mean inadequate time to charge the fob battery. Have you tried leaving the fob close to your electric toothbrush charging base overnight?
yes im charging it using my wifeless mobile charger. but does seem to go flat rather quickly. will have to test it out on a trip down southampton in a couple of months.hopefully its not a fault on the pcb borad. Time will tell. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
The obvious question is the replacement battery you got a rechargeable one? 07MY RRS TDV6
yes mate its a rechargeable one. thanks tho |
