![]() | Home > Maintenance & Modifications > Megaflush |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
If the fluid was changed 4 years ago just add lube guard.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
If it's juddering then the torque converter clutch is already going down hill. A flush won't make it better. A tube of Dr Tranny will help until you get the TC changed. 2012 SDV6 - it's missing a couple of cylinders
chrisbarr35 Member Since: 26 Aug 2018 Location: Chesterfield Posts: 3 ![]() ![]() |
Thanks for the advice, makes sense to see how long I can delay replacing the torque converter using Lubeguard and getting the metal sump fitted at the same time as a new TC in the future.
I wouldn't be hard over on a metal sump. (they are prone to leak, don't always have a drain plug)
