![]() | Home > General (L494) > L 494 Oil dilation |
| wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
As above.
| Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327
There are also other explanations coming out.
| Dave Harries Member Since: 14 Mar 2018 Location: Bath Posts: 12
Did a bit of investigation on my car today I went out and data logged the injector timing, rpm and boost, I seems that the engineers at land rover have retarded the injector timing so it injects after TDC at 1000-2000 rpm at most boost pressures. I also have a copy of the ecu data and there are approx 20+ injector timing maps ( with out pre and post injection maps ) and most are retarded. I guess this is there attempt at passive regeneration of the DPF and the cause of allot of the problems with oil dilution. |
I guess that was their "workaround " to keep EGT up at low engine rpms? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
The egt's did not seem that high in the region of 300-400, on cruise, the only time I got decent egt's was at about 3000 rpm with 1.8 bar of boost when it hit 600. |
| RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56
My service message has popped up for the 3rd time in 22k miles and 20 months of ownership. Last time, the oil was changed under warranty rather than using the service. Between the last 'service' and now, I have done nearly 3k miles on European motorways.
Just checked the next service menu and the mileage has dropped 500 miles, I have only done 180 miles since the oil change |
| Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145
[quote="IRBails"]
Oil is cheap insurance IMO , although new syn. oils can do the distance no issue it is the dilution that is the issue.[/quote Just had mine changed and service said no charge BUT cars built after June 2017 will have to pay "very odd " |
I can't recall the "light off" temperature for the DPF at the moment. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
| IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873
Good stuff this now makes sense. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Bye the way my oil changes have all been at the right time except for the last which was about 1500 miles short. As stated I have requested oil test so I will let the group know the results. I am running the V8 diesel so in the minority here. It does seem that if the regen is the issue and caused oil dilution it isn't the oil dilution that triggers the service required but the number of regens? So the real issue is why is the regens being triggered, firmware I suspect. Reminds me of the OP who had constant regens and was told it was his driving , all points to a fault in the diagnostics. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783
These engines were never designed to have DPF's and because of that they are not optimally located in the exhaust systems. They don't get consistently hot enough to burn off the ash without a re-gen. I, briefly, had a 1.6 Honda Civic with the Euro 6 engine which was designed with a DPF by placing it next to the exhaust manifold so it got hot quicker. That being said, in the 9 months I had it, it still did 2 re-gens. Go figure eh. |
According to my oil test I had 6% dilution, not good. I am waiting for the full results. Also doesn't seem to be markers for syn. oil. All services done by dealers which I would assume would use the right oils as they are LR dealers. Need to get another sample done now to see if this is ongoing. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Found this interesting read. Of note the stop start function which I turn off is not good for Fuel dilution , DPF cycles are also mentioned. I think I will go to 15,000 k oil changes now.
