![]() | Home > In Car Electronics > Parking sensor fault ‘06 supercharged |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Mine are the opposite, as soon as I select reverse they go mental so I just turn them off now. Steve. |
Either a faulty sensor or a chaffing wire usually |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
Grrr sounds expensive Noisy black one |
Sensors are between £10 and £30 on the bay and if the bumper is off takes about an hour-2 hours to get off so not really hard to be honest |
Packard66 Member Since: 04 Sep 2018 Location: Croydon Posts: 5 ![]() ![]() ![]() |
how to check which sensor is not working? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
reading the fault codes is best. |
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 ![]() ![]() ![]() |
Did you find a fix for this? Mine have decided to start doing this. Put in reverse just a long tone that lasts forever. Then when you change to drive they just beep and go crazy even when theres nothing around |
Rangey Davey Member Since: 25 Oct 2018 Location: High Wycombe Posts: 8 ![]() ![]() ![]() |
I had two sensors that were not working, one on the front one on the back. I found which ones by putting my ear right up to each sensor in turn and listening for a ticking which tells you that it’s working. Managed to replace both sensors of eBay and without totally removing bumpers just loosening them and getting my hand in! |
Awesome thanks, i'll try that. Do you just need to engine on for it? Or does it need to be in reverse? |
No need for engine as it’s quieter. Ignition on and in reverse, I think I had to put a brick under the wheels and take the handbrake off. |
