Home > Technical > power steering
cerdad
power steering
The alternator packed up on my 08 tdv8 which i changed ,since then the power steering has got heavy,no leaks or anything,the rest of the car is fine ,is it a software issue ,all the dealers want me to book it in but i am not prepared to do that ,dont like their prices .
Post #564418 Mon Sep 03 2018 8:13pm
Disco_Mikey
Check the air suspension module for fault codes relating to the sensor on the steering rack Thumbs Up
That, or the lower UJ is seizing up
Post #564419 Mon Sep 03 2018 8:39pm
cerdad
Thanks for that,where is the module located?
Post #564509 Tue Sep 04 2018 10:26pm
The air suspension control module is on the a-pillar up behind the dash on the driver's side. It's accessed from the footwell relatively easily.
When he says "check the module for fault codes" that means sticking a suitable reader in the OBD port. 2012 SDV6 - it's missing a couple of cylinders
Post #564510 Tue Sep 04 2018 10:35pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
WHAT
Is the Lower UJ Mikey?
Post #564582 Wed Sep 05 2018 9:03pm
Brit Plumber
UJ = Universal Joint 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564596 Wed Sep 05 2018 10:47pm
