Home > Technical > loss of power and white smoke from exhausts
Disco_Mikey
It is always necessary to cool the turbos before switching off
Post #564386 Mon Sep 03 2018 10:14am
PIG88
The stop-start system on recent models gets in the way of letting the engine idle while the turbos cool. Probably best to disengage the system before coming to rest after a hard run.
Post #564398 Mon Sep 03 2018 5:06pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Mikey/Brit, I agree. Some don't... surprisingly. You'd think a bill heading for £4k (SDV6) and a body off if you Censored your turbos might influence but there you are.
Post #564407 Mon Sep 03 2018 6:54pm
Disco_Mikey
My TDV6 is on its original turbo at 207k miles
In fact, I've never had a turbo failure on any of my cars Wink
Post #564410 Mon Sep 03 2018 7:23pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
When does the need to idle for 30 seconds arise, only when shutting down after a sprightly drive, or after grandad style driving aswell? I never think about this, but it usually takes me at least 30 seconds to reverse into my drive and my driving is mostly pretty calm, especially near my home which is just outside a small village. Should i be considering sitting stationary idling for 30 seconds aswell? 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #564414 Mon Sep 03 2018 7:42pm
Father Jack
Jammy sod Mikey... Mind you mine going on the RRS was my first ever, including a couple of Saabs with similar 200k plus mileages. And my first ever inlet manifold fail. And first, second and third wheelbearing failures. And first ever handbrake failure. Second ever alternator failure too so not all bad Smile
On form though, simply a brilliant drive, esp Alive tuned.
Post #564415 Mon Sep 03 2018 7:54pm
Father Jack
From what you say you should be fine. I had more in mind a good thrash up the M5/6/74 and A702 from the Mids home, so lots of fast running for 5 hrs. Though any decent drive at pace/high revs for a reasonable time and just let it tick over. 20 or 30 secs is nothing in the scheme of things.
Post #564416 Mon Sep 03 2018 7:59pm
