Home > Technical > loss of power and white smoke from exhausts
richtdv8
United Kingdom 2008 Range Rover Sport TDV8 S Java Black
Aaargh, after pulling out of a junction and flooring my 2008 rrs tdv8 I experienced a loss of power and clouds of white smoke.
I stopped the engine after pulling over, waited a few mins then started the engine again, same white smoke.
I suspect issues with one or both the turbos's.
lifted the bonnet, coolant looks good, no white sludge in oil filler cap. no oil in the exhaust tips.
Ive had the vehicle brought back home on the back of a recovery waggon.
My question is,
What can i check myself before getting the experts involved?
I'm a competant mechanic but geared up for major engine work.
Is there anything I can monitor with my GAP tool, pressures etc?
Car has 70k miles and a BAS remap via GAP Tool.
Post #564328 Sat Sep 01 2018 9:43pm
Stuart
White smoke is generally water isn't it? Head gasket, etc.... Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #564329 Sat Sep 01 2018 9:46pm
richtdv8
Possibly, but the coolant did not boil out when I took the expansion tank cap off and there was no white sludge in the oil filler cap.
I suppose I could start the engine and determine if its water vapour coming out.
Post #564331 Sat Sep 01 2018 10:02pm
Disco_Mikey
Sounds like turbo...
Post #564337 Sun Sep 02 2018 6:15am
I agree with Disco_Mikey. Same symptoms as when my old TDV8 blew its turbos. 2012 SDV6 - it's missing a couple of cylinders
Post #564339 Sun Sep 02 2018 8:15am
richtdv8
Ay, more than likely turbo or turbo's.
Is there a way to confirm it's the turbo before removing the body.
what's a ball park figure for a repair of this kind.
Is there anyone in the south yorks area that can do this work bar the main dealer.
Post #564348 Sun Sep 02 2018 12:26pm
Disco_Mikey
Downpipes off, and check for oil or seized shaft
Also worth checking the boost pipes at the bottom of the Intercooler, most likely they will be full of oil...
Post #564350 Sun Sep 02 2018 3:23pm
richtdv8
I have just put my flexi camera down the air intakes to the turbo. on the front pipe it came out covered in oil.
Post #564352 Sun Sep 02 2018 4:59pm
Disco_Mikey
Ouch Big Cry
Post #564353 Sun Sep 02 2018 5:10pm
There's always a bit or oil near a turbo.
It when you get soaked you need to worry Laughing
Post #564364 Sun Sep 02 2018 6:46pm
IRBails
Australia
Low miles for a turbo ? Not saying it isn't but these days turbos should go way longer. I have seem turbo land cruisers with 600,000 Kilometers and still going well. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #564373 Sun Sep 02 2018 11:12pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Fingers crossed for you. Did both the turbos on my SDV6. It was not a cheap job.
Post #564378 Mon Sep 03 2018 7:44am
Brit Plumber
I’ve read on the forum that the TDV8 Turbos can fail early if the engine is turned off while the Turbos are still spinning at fast RPM. Something to do with the distance the Turbos are from the engine and the long oil pipes (Because the engine bay is so tight). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564379 Mon Sep 03 2018 7:46am
Father Jack
I have personally always let any turbo car I have owned spin down first before switch off, and after a hard drive idle for 30 secs or so. That said I mentioned this on a separate thread and it is fair to day others disagreed saying on a modern car not necessary. I prefer my way but each to their own I suppose.
Post #564380 Mon Sep 03 2018 7:50am
Brit Plumber
For the sake of 30 seconds it’s worth it....or take the risk of the bearing burning out, easy choice for me. 2019 5.0 SC SVA (Current)
Post #564384 Mon Sep 03 2018 9:12am
