![]() | Home > Faults & Fixes > Black smoke underload |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
First of all, any fault codes? |
Rodgerwcostello Member Since: 01 Sep 2018 Location: Scotland Posts: 8 ![]() ![]() ![]() |
I have had smooth running error/fault that is the only one. Not a thing else |
Black smoke is top much fuel or not enough air. A smooth running fault would possibly point towards an over fuelling injector, boost leak, turbo issue, or lack of compression... |
I'm tempted to go down the overfuelling or faulty injector also as everything else was checked by lr , turbos eyes etc.
I am unsure if an injector clean is something to do prior to paying out hundreds for a new injector and labour tbh |
I'd suggest money would be better spent on a decent couple hours diagnostic work than an injector clean... |
Yeh I think your right too as pointless guessing on each thing. I actually think before I changed the egrs it was smoking , the lumpiness has just started since they were fitted, so either the eyes are faulty which have been tested as ok, then some connection isn't right somewhere , thanks also ill get it booked in and wait for the end bill lol |
It would appear its the os inlet manifold.
A well known fault. But are you sure it is just the inlet manifold ? Did you also get codes read ?
Well they said couldnt do a diagnosis or the computer said this cause this was leaking, i dont have any warnings at all on the car.
The only thing that happened was the intercooler hoses burst and then limp mode.
