Home > Maintenance & Modifications > Door cappings faded?
PompeyDave
Hi all, my drivers door capping looks like this. Shouldn’t it be the same colour all over?
Post #564266 Fri Aug 31 2018 8:40pm
the bottom bit ?
lacquer gone milky ?
If its less than 3 years old, get um to fix it under warranty
Post #564268 Fri Aug 31 2018 8:50pm
PompeyDave
Can’t, it’s a 2010 model. Doesn’t look right does it?
Post #564271 Fri Aug 31 2018 9:36pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I had an American conversion van full of wood trim which went like that and it eventually peels off. I reckoned at the time it was due to damp as I finally discovered the sunroof leaking, I should have fixed it sooner as I could see the windscreen steamed up each morning.
Have you any leaks or steamy windows (when not occupied Laughing ) 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #564273 Fri Aug 31 2018 10:00pm
no.
but it maybe better to live with it, rather than fix it
I know in 2001 they had a problem with the wood processing in the factory, which led to that.
Maybe it happened again 9 years later Laughing
Post #564274 Fri Aug 31 2018 10:01pm
PompeyDave
I don’t have any leaks at all. Are they easy to get off the door card?
Post #564275 Fri Aug 31 2018 10:12pm
Brit Plumber
I’d go for the Piano Black trim and change them. Easy to replace once the door card is off which itself isn’t to difficult to remove, just have a bag of plastic clips ready in case some break. Cheap enough on eBay. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564279 Sat Sep 01 2018 6:32am
PompeyDave
Ok, cheers guys. I've bought an 'as new' set off ebay for £40 inc postage. Looked at the Piano black versions, but I don't think it would go with the cream leather. Dunno, it's a personal preference thing I suppose.
Post #564281 Sat Sep 01 2018 7:43am
PompeyDave
Here's what I got from eBay...
Post #564291 Sat Sep 01 2018 10:48am
Brit Plumber
The Piano Black with Ivory was a Autobiography option and goes really well.
You’ll have all those changed out in less than hour. 2019 5.0 SC SVA (Current)
Post #564314 Sat Sep 01 2018 5:30pm
