Home > General > Unstable When Towing |
Tue Aug 28 2018 10:01pm |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Hi I once had same problems you are haveing
Tue Aug 28 2018 10:34pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
The tow ball on the RRS is a tad low and on a twin axle trailer this gives a very slightly nose down attitude. My TDV8 could also feel a tad wobbly with the standard removable ball. I put a Tow Trust bar on it - runs the ball higher - and it was fine. i moved the Tow Trust bar on to my later RRS and it feels fine too.
Tue Aug 28 2018 11:00pm |
No problems towing here, everything from tri axle Brian James trailer and twin axle sterling tin tent. Always rock steady, i find tyre pressures make a big difference so i run them as per the fully loaded sticker in the door shut. I run 255/55/19. Hope this helps and welcome to the forum 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Aug 28 2018 11:01pm |
Magic7 Member Since: 28 Aug 2018 Location: Hertfordshire Posts: 3 |
Thanks for the replies. I adjusted the tyre pressures per the recommendations on the sticker inside the fuel flap before towing (to the lower of the two specified pressures since it was just me and the trailer). The car currently has 275/40/20 tyres (Pirelli P Zero Asymmetric).
Tue Aug 28 2018 11:13pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
What about your shocks, it's a 2007 RRS so if still original shocks and high mileage they'll likely be well past their best, especially if it's previously had a hard life of towing? Just because they pass inspection at MOT doesn't mean they're perfect under load.
Wed Aug 29 2018 12:39am |
I'll bear the shocks in mind if nothing else works, however it has done 65000 miles and had neither a towbar nor trailer sockets fitted when I purchased it so I was hoping they would be alright. |
Wed Aug 29 2018 6:17am |
I've just noticed this bit, I too have 275/40R20 tyres and just a few weeks ago I took the caravan a run and thought something was broke. It's a 1800kg gross twin axle that normally runs rock solid to the point I often forget it's behind me. I was on twisty North Scotland roads and the RRS was unsettling to say the least. Once I'd covered 200+ miles (it stabilised a bit when on normal roads) I realised I'd forgot to increase my tyre pressures from normal running pressure, so I topped them up to the max recommended pressure and what a transformation, I was back to forgetting it was behind me again (I cannot remember the pressures and I'm away from home so can't check). Before you go looking for a problem, try pumping the tyres to the upper settings. A 150 - 180 noseweight is a lot especially with a full trailer/horsebox which then isn't a static weight when driving. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Aug 29 2018 7:23am |
Who fitted your tow electrics? Did they update the CCF for towing? I’m pretty sure that when you plug into the towing socket, it detects it and turns off the reverse parking sensors and changes your suspension settings to reflect you have additional weight in tow. I had to add that I had tow electrics fitted and then select the correct version out of a choice of 5 I think it was. 2012 5.0 SC AB
Wed Aug 29 2018 8:03am |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
I experienced similar issues towing 2t twin axles with MY10 and MY13 RRS - felt unstable if you went over 60 which I know is the speed limit and I had stabilisers
Wed Aug 29 2018 9:48am |
Exactly that 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Wed Aug 29 2018 12:52pm |
