![]() | Home > General > Help please - work done, now something doesn't look right! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9149 ![]() ![]() ![]() |
It looks like they have put on the later filler neck. The earlier version - as on your 08 - was metal and didn't have the misfuel device in it. Would be worth picking up the reset device just in case you activate the misfuel device at some point. 2012 SDV6 - it's missing a couple of cylinders
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 ![]() ![]() ![]() |
Thanks for the quick reply. It's tricky to see from my pic, but in the photo with the cap off, you can just about see a thin bit of black plastic runs around the edge of the whitish/grey circular piece with the hole in the middle. This piece of black plastic looks as though it's broken around the edges to me. Any thoughts? 2008 RRS HSE Stornoway Grey |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5148 ![]() ![]() ![]() |
Looks to me like they have ripped off part of the rubber seal that locates in a groove in the top metal part of the filler neck.
Thanks Col - worth complaining about and getting the garage to sort? I sit something I can sort myself with a nice new stanley knife blade?! 2008 RRS HSE Stornoway Grey |
This is what it should look like, I think they have actualy torn the rubber seal when they pulled the filler neck out, so would need replacing.
Thanks again Col - I'm going to contact the garage and ask them to sort... heaven knows they've had enough of my hard-earned! 2008 RRS HSE Stornoway Grey |
This is what you or should I say they will need around £45.00 LR014044
That's great - many thanks again for your help. 2008 RRS HSE Stornoway Grey |
I emailed the garage and got the following reply -
No, it's not petty to expect them to do the job correctly.
No, it's a LR-specialist Indy in Essex. 2008 RRS HSE Stornoway Grey |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Their answer - reply is simply not good enough !! could it be classed as dangerous ? Good luck 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White ![]() 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
It was put there for a reason.
Thanks all.
