Home > General > Battery replacement advice needed - 2011 RRS
J2D
Had the low power mode warning come up as I started her up Tuesday evening, drove to the restaurant and back no problems, but in the morning the battery was flat, charged the battery that night, next afternoon battery flat again, even though the charger was indicating the battery was charged. So I’m assuming the battery is dead
What battery do I need? And where’s the best place to buy one?
I’m sure on my previous cars I have used Eurocarparts
Thanks in advance
John
Post #563873 Fri Aug 24 2018 7:57pm
Red Arrow
Euro and put the reg number in and you will have a choice of brands Thumbs Up
Post #563875 Fri Aug 24 2018 9:24pm
J2D
Done that, also get a choice of batteries - C17, C19 and C20! Which one is preferred?
Post #563878 Fri Aug 24 2018 10:14pm
I used a Varta G14 AGM Stop Start battery. Came from Tanya Batteries delivered next day. The 020 will not fit it's to long 393mm as opposed to 353mm, unless battery box and wiring is modified slightly. 017 and 019 are same dimensions so both will fit, not sure of the rating of each, though imagine 019 is slightly higher Ah and CCA and possibly terminal height lower on 017 depending on manufacturer.
Post #563882 Fri Aug 24 2018 10:36pm
J2D
Thanks for the advice
The C17 is 88Ah and cca is 680A
The C19 is 95ah and cca is 750A
Both are same dimensions
Will either of these do? Or do I need the C19?
Post #563892 Sat Aug 25 2018 6:35am
Personally I would go for the highest rated one I could get in.
Post #563893 Sat Aug 25 2018 6:53am
J2D
Thanks mate,
C19 it is then! Would you pay the extra for the Bosch? (£65) or is there not much difference between the Lion and the Bosch?
Also, when changing the battery is there anything I need to know/do to stop me causing problems with the electrics?
Do I disconnect the positive 1st? Then when reconnecting, the positive 1st again?
Sorry for all the questions, and thanks for you help 👍🏻
John
Post #563902 Sat Aug 25 2018 10:39am
No, disconnect Negative first and reconnect last, nothing else to worry about but bare in mind the battery is quite heavy and relatively tight fit, move leads well out of way first.
Post #563903 Sat Aug 25 2018 10:56am
J2D
Thanks mate
Post #563922 Sat Aug 25 2018 8:32pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
What ever you do DO NOT BUY A LION BATTERY!!!
If you do you will be roaring when it goes flat.....
Post #563929 Sat Aug 25 2018 10:15pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Battery Monitoring System Reset
As your RRS is a 2011 model it may have a battery monitoring system - A lot of markets had a BMS from 2010 onwards. I was under the impression that this needs to be reset when changing the type of battery or putting in a battery of different capacity and if you don't the charging system starts doing funny stuff.
Post #563939 Sun Aug 26 2018 8:04am
Never reset mine and never made a blind bit of difference, if you do reset it would suggest you make sure battery is fully charged first.
Post #563940 Sun Aug 26 2018 8:10am
Meiang
Battery size
The battery in my 2010 TDV8 is a AGM 95Ah unit with 850CCA.
Post #563943 Sun Aug 26 2018 8:37am
N60613
Bosnia Herzegovina
I made one of this, made replacement much easier Very Happy
Thumbs Up RR 2012 4.4 TDV8
Post #563947 Sun Aug 26 2018 9:48am
Not quite sure that would work on a sport as the battery is in a different position to the fullfat. The position of your wooden plank is directly over the battery on a sport as it is.
Post #563949 Sun Aug 26 2018 10:08am
