![]() | Home > Maintenance & Modifications > Intercooler replacement |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Hi all,
Here's a air-con condenser removal from a disco so you can see what to strip from the front to remove it almost the same as a sport also i think the front bumper needs to come off as i think the intercooler is right at bottom if i remember |
Here is another one for a disco but with more pics you will see the difference to the sport and change accordingly |
Thanks Geoff, that's brilliant. Never thought of looking at Disco site, is most of the engine/drivetrain maintenance similar to the v6 disco? eg cv joints etc?
Yes they use the same components just different bodywork |
The inter-cooler is below/behind the crash bar so all that needs to come out |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I have just looked at that landrover discovery method. It looks like the intercooler is small compared to mine so would probably come out easier. I forgot to mention that I lifted the radiator units up so they could go back towards the engine to enable room for the intercooler to be removed.
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Mine was duff recently and rather than drop it in the indy (3 week wait at Land Ranger), one of our our own vacuum cleaner engineers (an ex Mercedes commercial van mechanic) did it.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5053 ![]() ![]() ![]() |
They are green sealing plugs to prevent water getting in.
Brilliant, thanks Andy! Well, not brilliant really, thought it might be reason for Red suspension light on constantly (more like wishful thinking!)
Start the engine, take off the Dynamic Response reservoir cap and see if you can see the oil flowing back into the reservoir. If you can see flow, the pump is producing some pressure at least. Did the garage replace the filter after the fault or before? Filter replacement shouldn’t require bleeding but if they thought it did, and tried, they may have introduced air into the ARB. That’s a simple fix with some home made bits. 2019 5.0 SC SVA (Current)
If you come down Newark way anytime give me a shout and we can check the block etc. With my DIY test kit. 2019 5.0 SC SVA (Current)
Thanks, very generous offer, might take you up on it in near future! |
