Home > Maintenance & Modifications > Washer pump
geoffsnook
Washer pump
Hi does anyone know the route of the front windscreen washer pipe have changed the pump but the washer only seems to work on passenger side.No matter which way i configure the washer jets so i assume it has a kink or has anyone else had this problem have removed battery and looked around can see it as it disappears around the bottom of screen but cant see it anywhere else till it appears at the front of car also the rear washer ha no water coming out but pump works Thumbs Up
Post #563684 Tue Aug 21 2018 4:08pm
its within the wiring loom
If you remove the passenger front wheel arch plastic liner, you should get a better view of it.
But first I would remove the drivers washer jet, pull it and the pipe tight/tought, press the wash button with the other hand. and see if you get wet.
Post #563696 Tue Aug 21 2018 6:56pm
geoffsnook
Thanks it does come out of the pipe but very slowly but hardly if any from the nozzle does not seem to make any difference if i take out the one way valves so from the top it goes down under the wing Thumbs Up
Post #563697 Tue Aug 21 2018 7:08pm
Brit Plumber
Can you blow through the pipe? Cheap screen wash does a good job of turning to jelly. Mine got blocked and I cleared it by running boiling water through the pipe work. Watched all the crap spit out on the screen. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #563723 Wed Aug 22 2018 8:51am
geoffsnook
Well just pulled the liner can find nothing in there to do with the washers Big Cry
Post #563727 Wed Aug 22 2018 9:25am
Brit Plumber
What car is it? The L320 has a big water bottle with the pumps and pipe work between the front bumper and wheel arch liner. 2019 5.0 SC SVA (Current)
Post #563729 Wed Aug 22 2018 10:26am
geoffsnook
It is a l320 just had the wheel arch liner off can’t see anything in there to do wiyh it so have bought a bit of pipe to illuminate a few things Thumbs Up
Post #563730 Wed Aug 22 2018 11:00am
geoffsnook
Can get them both working now by taking out one way valves but the spray is really weak so maybe some white Cingular in there to clear the pipes out Question
Post #563731 Wed Aug 22 2018 11:04am
Brit Plumber
Look at this link, scroll down to Bobs post and you can see a photo showing the location of the bottle on the right of the photo (left of car).
Put some boiling water in the bottle and run it through. 2019 5.0 SC SVA (Current)
Post #563733 Wed Aug 22 2018 11:27am
Brit Plumber
Bobs Gallery showing the topic procedure
http://www.rrsport.co.uk/gallery/albums/us...ervoir.pdf
Posting with good photos
http://www.rrsport.co.uk/forum/topic30858....her+bottle 2019 5.0 SC SVA (Current)
Post #563734 Wed Aug 22 2018 11:35am
geoffsnook
Yeah have had all that off mate nothing to be seen there got both sets working but the jets are not even hitting the screen so hopefully the white vinegar will help clean it out as the pump is a new one so all it can be is a blockage or a trapped pipe but can’t see where they really go without stripping out half the top end by the battery Thumbs Up
Post #563738 Wed Aug 22 2018 12:06pm
often cars have a filter in the grommet between the pump and bottle.
This gets blocked and results in poor performance.
IF you remove the small pump, water should gush out like a fountain. If it only dribbles a little the filter is blocked. Remove filter and clean.
(get someone else to clean the filter while you hold your thumb over the hole!) or have a bucket of warm water handy to clean it in.
Post #563739 Wed Aug 22 2018 12:12pm
geoffsnook
Hi mate it’s a new pump and could not see any filter in the bottle itself Thumbs Up
Post #563740 Wed Aug 22 2018 12:14pm
Did you remove the black seal between pump and bottle?
Post #563742 Wed Aug 22 2018 12:53pm
geoffsnook
Yep used the new one that came with new pump Thumbs Up
Post #563744 Wed Aug 22 2018 1:06pm
