Home > Technical > Dab
geoffsnook
Dab
Hi would anyone know if it would be possible to fit a dab unit in to a 2005 range rover sport from a later model i already have the screen from a 2010 sport fitted so i think that it has the internals for a dab connection and if poss would i have to ask pat at gap to help with the ccf Thumbs Up
Post #563604 Mon Aug 20 2018 5:32pm
I think will find the DAB antenna is part of the roof mounted GPS aerial, it is not part of front windscreen if that is what you meant. The FM aerial is part of the N/S quarter light glass I believe and the TV one is in the O/S glass on a facelift car.
Post #563647 Mon Aug 20 2018 10:09pm
geoffsnook
Hi Col no I just wondered if it could be retrofitted to a 2005 sport Thumbs Up
Post #563649 Mon Aug 20 2018 10:37pm
Can't really answer that I'm afraid, but looking at the wiring diagram it's almost looks like a stand alone system, with a live power feed and a feed in and out from the MOST circuit into the module, plus some coax type leads out to a amplifier and aerial and a couple of earths. Sounds quite simple really Rolling with laughter might be able to pick up the bits and pieces wiring etc. from a breaker. As have said before not auto electrician or audio engineer so unable to say one way or the other really. If you pm me a email address I can send pdf file of wiring so you can see for yourself which may help.
Post #563651 Mon Aug 20 2018 11:06pm
