Home > General (L494) > Another Air Con,Issue!
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Had my car regassed twice by a garage and by a dealer too. All state there is no leaks in the system but days / weeks after a regass, it stops blowing cold.
Both times they have told me they have added dye.
Any ideas, I can not keep forking out £150 for a regass to last a month!
Post #563607 Mon Aug 20 2018 6:32pm
geoffsnook
Take it back to them and tell them it must have a leak as the gas is gone and make them find it if they have put a dye in it if the gas has gone then there will be evidence where it came out Thumbs Up
Post #563609 Mon Aug 20 2018 6:58pm
the_big_1
Both said no leaks and want another £150 to test it as they have to remove the gas and weigh it to see it's gone down or not
Post #563611 Mon Aug 20 2018 7:05pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
When asking my local garage to top up my P38 gas, during chit chat conversation I was told that if they top up a car with leak then they can be liable for a £10k+ fine (illegal harmful gas discharge). I'm not sure of this could be used as leverage, you pay for the leak test but if leaking then they refund and refill for free.... 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #563612 Mon Aug 20 2018 7:13pm
geoffsnook
How did they test it with a vac test or with nitrogen Exclamation
Post #563613 Mon Aug 20 2018 7:20pm
the_big_1
I am wondering if it is leaking though. I have ordered a UV touch to see if I can spot any dye. I guess the dealer will just the excuse "it wasn't leaking when filled it, this is a new fsult"
Post #563614 Mon Aug 20 2018 7:21pm
geoffsnook
The condenser at the front is very common done 2 on mine but to leak test them the must use nitrogen as with a vacuum it can seal up a small hole so if they are not air-con specialist then find one Thumbs Up
Post #563615 Mon Aug 20 2018 7:24pm
the_big_1
Hi ya,
One is a main dealer, one only does car air con.
I would have thought any leak would show the dye somewhere?
Post #563616 Mon Aug 20 2018 7:33pm
geoffsnook
It will but they can be very small look at the condenser behind the front bumper and any joints you can see Thumbs Up
Post #563618 Mon Aug 20 2018 7:44pm
the_big_1
That's my first port of call. Is it the cooler across the front at the bottom?
Post #563619 Mon Aug 20 2018 7:46pm
geoffsnook
You should see it at the bottom it's right in the way of any stones being flicked up thats where my first one went but the second had stone hole's through the grill Thumbs Up
Post #563620 Mon Aug 20 2018 7:52pm
geoffsnook
Also why dont you ask the air-con guy to just check for the dye as if he has put it in the least he could do is look for the dye Thumbs Up
Post #563621 Mon Aug 20 2018 7:55pm
the_big_1
I have emailed the dealer stating that's the original fault (that appeared after a service) has come back after about 4 weeks. They also stated they had put dye in.
It's weird as it started to play up with the drivers side vents blowing warm and passenger side freezing cold.
Wasn't sure if there was something else that could cause this fault
Post #563622 Mon Aug 20 2018 8:00pm
Welshian
Wales
This is exactly like my fault, see under "RRS2 Air Con Failing" posted earlier today. My 1955 Morris Minor doesn't suffer from this problem Rolling Eyes RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #563626 Mon Aug 20 2018 9:01pm
the_big_1
Are you having any joy? I just wonder if there is another issue other than a leek.
Post #563627 Mon Aug 20 2018 9:08pm
