Home > Maintenance & Modifications > L320 2010 turbo actuator
Godders
I have started a new post for future reference and it is in regard to the turbo actuator.
I have located the actuator with assistance from a post on the disco 4 forum and the link to this post is below.
https://www.disco3.co.uk/forum/csov-sticki...63490.html
I sprayed a load of WD40 onto the push rod and moved it manually but on a ride out, after 5 -10 minutes the following warnings came up:
P22D4-17 Turbocharger turbine inlet valve position sensor circuit - General electrical failure - circuit voltage above threshold.
P22D2-77 Turbocharger turbine inlet valve stuck open - mechanical failure - command position is not reachable
P22CF-71 Turbocharger inlet valve control circuit - open - Mechanical failure - actuator is stuck
When this happens the car has the restricted performance which means it is ok on the flat and downhill but struggles uphill, but there is no black smoke from the exhaust or limp mode.
Is this just a case of a new actuator to solve the problem or could it be more sinister ? Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #563274 Wed Aug 15 2018 6:49pm
geoffsnook
I think the actuator is still sticking Thumbs Up
Post #563276 Wed Aug 15 2018 6:54pm
Godders
I'm hoping that is the case as a new actuator is about £70 and an hours work at most. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #563280 Wed Aug 15 2018 7:07pm
Disco_Mikey
None of those faults are related to the turbo actuator...
Post #563312 Thu Aug 16 2018 6:54am
Godders
can you point me in the right direction as to the actual problem ? Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #563315 Thu Aug 16 2018 8:15am
Disco_Mikey
Re: L320 2010 turbo actuator
P22D4-17:
Quote:
Using the manufacturer approved diagnostic
system perform the (Turbo, EGR and air path
dynamic test) routine
system check datalogger signals, Turbo Shut Off
Valve Opening Position - Commanded (0x03F0)
and Turbo Shut Off Valve Opening Position -
Measured (0x03F1). Refer to the electrical circuit
diagrams and check the turbine intake solenoid
control circuit for short circuit to power. Check
power supply to the solenoid. Repair harness as
required. Clear DTC and retest
If this DTC is logged with P0235-94, P00BD-07,
P1247-00 & P22CF-71, suspect turbine intake
solenoid sticking open
If this DTC is logged with P1247-00, P0235-94,
P00BD-07, & P22CF-71, suspect blocked low
pressure air intake
Check and install
P22D4-17:
Quote:
The engine control
module measured a
voltage above a
specified range but
not necessarily a short
circuit to power
This is the long term
adaption limit
diagnostic. It
diagnoses that the
adapted values for the
actuator end stops is
outside of tolerance.
This could be caused
by sensor drift over
time
Turbine intake valve
position sensor stuck
P22CF-71:
Quote:
Turbine intake
solenoid sticking
closed
Turbine intake
Intake air system,
blocked low pressure
air intake. This failure
mode can be caused
by snow packing in
the intake system.
Symptoms often
disappear after the
vehicle has been
warmed and heat
soaked. Similar
symptoms to seized
primary turbo
Clearly, there is an issue with the turbine intake solenoid or its associated circuits
The solenoid is at the top RH of the engine as you look from the front. This controls a set amount of vacuum to pass to the valve itself. If you have had any work done recently, a Vac pipe having been knocked off or disturbed would be the first place to look Thumbs Up
Post #563322 Thu Aug 16 2018 9:27am
Godders
Mikey, I have had a look at the solenoid and all appears in order with the electric wires in order and connected together with the vacuum pipes all connected and don't appear perished or damaged. Is it worth getting in a new solenoid as there is an original new land rover part for sale at £14.99 ?
For that kind of money it seems worthwhile to replace that and start investigating further if that doesn't sort the problem. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #563401 Fri Aug 17 2018 3:47pm
Godders
Ok I have now put a new solenoid on and this obviously cured two of the original problems/readings given and the following readings are now showing:-
P22D4-17 (2F) Turbocharger turbine inlet valve position sensor circuit - General electrical failure - circuit voltage above threshold.
P22D5-92 (2F) Turbocharger turbine inlet valve position sensor circuit range/performance - Component failure - performance or incorrect operation.
I have had a look at all the vacuum pipes where I can and all electric wires appear in order with no breaks or wearing of the covers or insulation causing any shorts.
The problem always occurs between 10 minutes and 30 minutes into a journey.
Any advice please or is it time to visit someone with more expertise than my limited knowledge. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #565431 Wed Sep 19 2018 12:29pm
jaxone
Denmark
Hi Godders.
Ever solved the problem ?
If yes, what was the failing part here ?
Thanks in advance.
Post #567666 Fri Oct 26 2018 7:45am
Godders
I have been to JLR in France where I live and they know that the problem is an electrical one between the two turbos.
The problem is that they could not replicate the fault to pin point the actual source of the problem.
I have now booked my car into an indie garage in England when I go back in November for a service and when I mentioned these problems he made reference to a 'diverter'. This is apparently an electrical item on the turbo that when the time / revs or whatever are right it then diverts from one turbo to another.
Sorry I can't be more specific but until I take the car in and he sees it etc I can't be certain what the part is actually called or exactly where it goes or a part number come to that.
Will update when visit is done. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #567716 Fri Oct 26 2018 9:51pm
jaxone
Denmark
Thanks for getting back to me.
The "diverter" you talk about then it must be the turbo shut off valve. Hopefully is only that Smile
Please let us know when you get it sorted.
Thanks.
Post #567720 Fri Oct 26 2018 10:57pm
Godders
will do Thumbs Up Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #567777 Sat Oct 27 2018 11:08pm
Godders
AT LAST.... having been into JLR in France just before xmas they did their own tests and initially came back saying both turbos need doing OMG !! I wasn't happy and questioned them with my own diagnostics reading. (this garage in France has Jaguar , Land rover and Volvo cars....and apparently all the mechanics work together and help out which may have meant that it was not a Landie mechanic looking at my car.) I did ask for a quote for the work...just for a laugh but two days later they called and asked to have the car back in for a day to do further checks. Well today was the day and they tested both turbos which are fine and confirmed it is the actuator (although they called it the command of the turbos) and quoted 1,500 euros to do the work. They explained that of the two turbos, there is a smaller one and a larger one...and it is the actuator on the smaller turbo that is having the problem. Part being ordered and hopefully arriving tomorrow and work done in next couple of days. Thumbs Up Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #572560 Mon Jan 07 2019 5:39pm
Stevepd
Good on you for preserving when you thought you were right Thumbs Up
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #572564 Mon Jan 07 2019 7:19pm
Godders
Got my car back today and no red light. Have then completed a drive of roughly 100 miles on fast single lane roads and motorway and all is running as should be.
Will now wait for the next drama Big Cry Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #572807 Thu Jan 10 2019 11:32pm
