Home > Faults & Fixes > Anothe suspension fault
sid1968
United Kingdom 2005 Range Rover Sport TDV6 Autobiography Java Black
My rrs 2006 2.7 has a suspension fault
When i am ststionary ie a giv way or traffic lights stationary
Sometimes orange suspension fault appears. When i drive off it dissapears
I then went into my 4 x4 denso screen and the suspension screen shows back right tyre jumping up and down. And when i select normal height it state slowing raising. Om quite confident it is the height sensor??
Would any of you pros agree??
I
Post #563047 Sat Aug 11 2018 2:42pm
DrRob
Get the codes read first Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #563053 Sat Aug 11 2018 6:09pm
Cymruambyth
Wales
And then sell it Steve.
Post #563072 Sun Aug 12 2018 10:19am
Antburgess89
England 2006 Range Rover Sport TDV6 Autobiography Stornoway Grey
Hi
I had this turned out to be height sensor.
On the 4x4 info screen if your tyre is floating around up and down means sensor is gone and your compressor will keep kicking in to alter and what it do is get hot and then say raising lowly. That's what happened to me. I replaced the sensor and all was fixed.
Hope this helps
Ant
Post #571874 Sat Dec 29 2018 10:22am
