Home > Technical > What is missing from here?
Brit Plumber
I went to fit the tow bar wiring to the car today and behind the left luggage compartment trim I found what I can only describe as a child’s bodge. I have 3 connectors loose and an earth which looks at one time to have been attached to an earth point. Someone has cut some wires and spliced in others but for what reason I don’t know. They have attached a wire to an earth point by removing the insulation on an earth wire and wrapping the core of the new cable around the core of the earth cable. No solder and no insulation tape. It begs belief!! Any ideas if I’m missing something or are they superfluous?
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #563018 Fri Aug 10 2018 10:34pm
Brit Plumber
I’ve now found out that the connectors are for the rear differential control module. So should a 5.0 Supercharged have one of them? 2019 5.0 SC SVA (Current)
Post #563020 Fri Aug 10 2018 11:15pm
The three loose connectors, Yellow, Purple and Black are for the Rear Diff Control Module which I assume are only used if you have the Electronic Locking Rear Diff fitted. The purple connector should be a 15 pin plug with just a pair of can bus wires one in pin 2 and the other in pin 5. The yellow plug should be a 8 pin and the black one 18 pin. As for the extra wires wouldn't have a clue, although when had a tracker fitted that's where they fitted the unit, so may have been something along those lines, but would have hoped for a more professional job than that bodge.
Post #563021 Fri Aug 10 2018 11:25pm
Beat me to it. The locking diff was a £750.00 option on all variants except factory pre facelift HST's.
Post #563022 Fri Aug 10 2018 11:27pm
It is actually possible to retrofit the locking rear diff - a chap on Disco3 did it some time ago as I remember. A bit of wiring required but other than that and the CCF update, it was good to go. 2012 SDV6 - it's missing a couple of cylinders
Post #563024 Sat Aug 11 2018 12:52am
Might work out bit expensive unless you can get used parts, new diff alone would be over 2k + surcharge unless you had old one.
Post #563026 Sat Aug 11 2018 4:37am
I didn't say it would be cheap, just possible. Wink This is LR - their spares are ridiculously overpriced these days when you look at some of the OEM prices for the same item. Sadly, I'm not aware of diffs being available OEM. 2012 SDV6 - it's missing a couple of cylinders
Post #563033 Sat Aug 11 2018 8:43am
Brit Plumber
Does the Sport really need a locking rear diff? If it did, wouldn't they have fitted it as standard? 2019 5.0 SC SVA (Current)
Post #563102 Sun Aug 12 2018 7:56pm
The reality is that 99% of people, 99% of the time won't need the locking rear diff.
Unless you're going really heavily off road, then no, it doesn't need a locking rear diff. The traction control and clever mapping of Terrain Response is good enough most of the time. If you were doing lots of cross axle work then a the rear diff lock would be useful then too but, again, the standard system is pretty decent anyway.
I merely mentioned it as an aside really. If I was replacing the rear diff then I'd consider fitting the locking version and having the wiring adjusted accordingly. 2012 SDV6 - it's missing a couple of cylinders
Post #563108 Sun Aug 12 2018 11:23pm
