Home > Technical > LED - has the fuse blown
Andyjay123
I accidentally used Audi LED in the car. At first they worked ut now they don't. I have swapped them out for Land Rover ones but they still don't work. I find this strange as the ones that don't work are the interior boot and doors. The ones that continue to work are the interior cabin ones.
Confused DOT com 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562505 Thu Aug 02 2018 6:22pm
All your tacky mods are gonna cost you in repairs Neutral
Suggest you remove all leds that don't work. Then fit one Bulb and see if that works
Post #562518 Thu Aug 02 2018 9:27pm
Andyjay123
They don’t work 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562521 Thu Aug 02 2018 9:40pm
If the rear reading lights above the doors don't work (Ines with switch) manually try switch. Check fuse 2
Post #562525 Thu Aug 02 2018 10:01pm
Andyjay123
The reading lights work funnily enough 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562528 Thu Aug 02 2018 10:08pm
probably blow the FET in the BCM CJB. These are £500 and contain imboilser.
Check you have fitted the leds the correct way round
Post #562563 Fri Aug 03 2018 11:46am
Scrumpy
Don't do what I did when changing the LED bulbs and blew a fuse!
I pulled what I thought was the right fuse, then realised it wasn't, I put it back and the engine started (no key in ignition!!).
I couldn't turn it off and had to pull the fuel pump fuse to get the engine to stop!!
Turned out I blew the BCM (Body Control Module) and cost me £2,500 to get fixed!!!
Heed my warning!!! Dumb mistake, lesson learned but hope no one else ever makes the same mistake as me 2016 RRS SVR Estoril Blue
Post #562574 Fri Aug 03 2018 12:23pm
Andyjay123
I haven't nor will i touch any fuses. the lights in the doors don't work but i can live with that. 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562575 Fri Aug 03 2018 12:37pm
Brit Plumber
The puddle lights on the right side of my car work when they want to. I just leave it like that. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #562578 Fri Aug 03 2018 1:28pm
