![]() | Home > General (L494) > SDV8 or SDV6 Warmup |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Yes,,to be honest it should be done with any engine especially ones fitted with turbo's petrol or diesel.Also when you are ready to stop the engine its advisable to drive the last mile with low revs to allow the oil to drain from the turbo.
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
Agree. Being mechanically sympathetic is always a good idea. Get it up to operating temp before booting it, that's under ten mins/5 miles for me in an SDV6, typically 1500 to 2000 rpm (typical shift points for the box anyway on a fairly normal commute), and if people aren't seeing it hit warmed up/gauge in the middle then they are probably not doing enough miles, definitely in a diesel and probably in a petrol too: frequent cold starts and not running at normal operating temp is not good for engines.
| naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1207
Get an coolant / oil temperature reading via IID tool or similar and work out what distance you need to drive before the engine gets to operating temperature, as the car's temperature gauge is fairly useless.
My14 SC temp gauge goes half way by the time ive got off our housing estate which is 3/4 of a mile
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
My sc does too now i have changed the stat |
that's not nearly enough time for the oil to get up to operating temp... I'll plug my IID and monitor the live oil temp and report back on the distance it takes to get warm. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245
All about getting the oil temp up regardless of car....my classics take a bit longer to warm up... MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
| DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528
Interesting topic and some interesting answers which is cool!
It’s any engine DM,especially ones with a turbo.
Cool
31C is very hot? Yes, the higher the ambient temperature and the longer the car has sat outside, the quicker the oil & coolant will reach operating temps. Accidentally revving it is not a biggie, as long as you don't do it for a sustained period of time. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic
For example, it's 13C outside right now, and you can see how the oil & coolant temps are almost the same as ambient (my car has been sitting in the garage overnight).
Whatever the ambient temp is on a sunny day, tin boxes do get very warm after constant exposure to heat, hence getting in a car on a hot day the heat hits you before you can get your air con on. If it works |
from the Workshop Manual, it looks like the operating temperature should be 96C:
