Home > General > Very Steep Driveway
KevAley
England 2012 Range Rover Sport 3.0 TDV6 SE Santorini Black
Very Steep Driveway
The driveway where I park my RRS is very steep, not very long but very steep. When I try to reverse off it sometimes stops going backwards and rolls forwards which is quite scary !! This is my first time owning/driving a RRS and I would appreciate any advice a more experienced driver could offer. Many thanks in advance.
Post #561812 Sun Jul 22 2018 10:34pm
best solution is to put it in Low Range to reverse out Thumbs Up --
Post #561818 Mon Jul 23 2018 8:08am
KevAley
Thanks very much, I will certainly give that a try
Post #561819 Mon Jul 23 2018 8:11am
Oldandconfused
Try reversing onto your drive so you can drive off forward.
Post #561820 Mon Jul 23 2018 8:43am
Low range, as suggested. 2012 SDV6 - it's missing a couple of cylinders
Post #561825 Mon Jul 23 2018 9:16am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Mine is on a short but steep drive. Never needed low range, even with the back seats down and a heavy load on board. I think I understand your problem in that I reverse up onto mine and drive forward out and you need to be fairly smart in coming off the gas and onto footbrake in order to stop the lurch forward in my case.
My tip is a steady amount of gas as it starts up the incline to stop position, then quickly onto footbrake at right place. Hold on footbrake and select neutral. Then fully select parkbrake while holding on footbrake. Then shift to park, gently releasing footbrake so as not to overstress park selector pawl in gearbox by a quick release of footbrake. This will work in any direction, solve the problem you raise and won't stress the gearbox..
Post #561884 Mon Jul 23 2018 8:59pm
Cymruambyth
Wales
^^^^^ This Thumbs Up Much safer too. Steve.
Post #561920 Tue Jul 24 2018 10:37am
still, if it's really steep, just use low range, that's what it's there for --
Post #561939 Tue Jul 24 2018 1:23pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Brakes not holding in low range and cold
I had a situation many years ago with my Discovery 1 V8. I started the engine up in a confined area one morning from cold with the transfer case in low range. The brakes would not hold the car during the fast idle period when in reverse or drive. No problem when the brakes were warm and no fast idle.
Post #561972 Wed Jul 25 2018 1:50am
I would select the EPB, once that's applied feather the foot brake so that the EPB is holding the vehicle, then apply Park. That way the EPB takes the weight of the vehicle, not the Park pawl in the gearbox.
Not sure how much difference it makes but it feels more sympathetic to me. 2012 SDV6 - it's missing a couple of cylinders
Post #561981 Wed Jul 25 2018 8:49am
Father Jack
That's what I was suggesting ?
Post #561985 Wed Jul 25 2018 9:34am
I would select park after releasing the footbrake, not before as you suggested (I think). 2012 SDV6 - it's missing a couple of cylinders
Post #562013 Wed Jul 25 2018 4:28pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Definitely!
Stop using the foot brake. Select EPB on, select Neutral, release foot brake slowly and confirm it is holding on the EPB then reapply the foot brake and select Park.
That way you are not holding on the transmission pawl - which is a very small pin.
Ps. If it doesn’t hold get the EPB adjusted.
Post #562017 Wed Jul 25 2018 5:40pm
Copilot
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Further to the other replies already offered...
Have you considered moving house? Thumbs Up
Post #562329 Mon Jul 30 2018 9:46pm
LJRH
Try parking sideways. Rolling sideways off the drive would be so much cooler. Noisy black one
Post #562417 Wed Aug 01 2018 9:06am
