Home > Maintenance & Modifications > Suspension noise
Brit Plumber
I would think the only real way to fix this would be to remove the clamps, remove the bushes and clean all rust off, smooth the surface, paint and fit new rubber and clamp up. The spray helps to pin point the problem but the rubber absorbes it and the weather will remove whatโ€™s left. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561705 Fri Jul 20 2018 6:02pm
micknolan
Iโ€™m thinking, a drive to Weston super mare, drive into sea ๐Ÿ˜‚
Kill the biatch ๐Ÿ˜ƒ
Post #561711 Fri Jul 20 2018 7:45pm
zaphod
Rusty Novice wrote:
This will give you an idea of what to look for Thumbs Up
https://www.howacarworks.com/suspension/ho...bar-bushes
Thanks, that's really helpful. I do hope the "fix" lasts longer than 20 minutes though! Laughing
Post #561713 Fri Jul 20 2018 8:55pm
