Home > Maintenance & Modifications > L320 2010 Onwards Side Vent Removal
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I was going through the process of replacing the side vents on my 2010 TDV8 with gloss black genuine Range Rover units when I came to a grinding halt. No matter how hard I pulled as per the Landrover instructions (from the top of the vent rear) or as instructed by PowerfullUK (from the bottom of the vent rear) I could not release the vent from the body panel. I was either going to destroy the vent and/or bend the body panel in which it is fitted to.
I did the usual web search and come up with a solution for the problem from rangerovers.net
You can access the top clips of the vent from the aperture in the fender where the bonnet hinge resides.
Both top clips can be released from this opening very easily (see picture 1 below)
I used a plastic pry tool (200mm long - see picture 2) to release the 2 top clips of the vent (see picture 3).
Note the original vent has 3M double sided tape at the rear of the vent (see picture 4). Even the new original Landrover vents dont come with this tape, so you will need to find a source for this on the replacement vents.
Post #561532 Wed Jul 18 2018 11:38am
I have replaced quite a few of these vents on both pre-facelift and facelift variants and have never had a problem removing them and have never come across any partly retained by double sided 3m tape, original factory fitted or aftermarket.
Post #561533 Wed Jul 18 2018 11:57am
Brit Plumber
I too had problems removing mine and had to go from the gap in the top. I followed the powerful instructions to start and broke one of the vents which is why I went from the top. They didn’t have and don’t need any tape on them, the clips are that strong. I also had to swop the back part of one of the new vents for my old one as both vents on my car are used rather than one real vent and one dummy. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561565 Wed Jul 18 2018 7:58pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Must be a pot luck thing. As with Col, no problem changing mine out for poweful uk ones.
Post #561566 Wed Jul 18 2018 8:47pm
Meiang
The 3M tape is there as a spacer and for anti vibration so it doesn't wiggle and jiggle plastic against paint and wear thru. Certainly on mine the rear end of the vent can touch the paint without the tape in place and the vent could be moved around quite a bit when installed.
If you have them installed without it I would recommend taking them out and putting some on there. They will over time wear a bare spot thru your paint and become a rust issue down the road.
Post #561585 Thu Jul 19 2018 3:42am
