Home > General > Some advice needed please
Jase
Wales
Hi all, new to the forum but been on the disco one for a while, had a D3 on a 55 plate when the cam belt tension bolt sheared and the engine eat its self, Big Cry so down to the question.. decided to get a rrs looking for around 09-10 with 3.0l as low milage as i can i have seen this.
https://www.gumtree.com/p/land-rover/2010-...1303191024
I know from the past the the lower arm bushes wear, cam belt a must, on the D3 i blanked of the EGR is this all i should look for as well as a FSH? are the turbos an issue or just go for a well sorted pre 09, again road tax are they all £500+
Many thanks for the help in advance and im sure i will be posting silly questions.
Jase
Post #560908 Sat Jul 07 2018 9:54am
geoffsnook
Hi it seems the cranks can be suspect on the 3.0 if you search on here and disco3 but it is a bit hit and miss with no reason apparently for them to let go other than that pretty much the same as disco4 issues Thumbs Up
Post #560909 Sat Jul 07 2018 10:03am
Cymruambyth
Wales
Re: Some advice needed please
Jase
You obviously didn`t watch When Teens Kill the other night about the Gumtree killers Shocked Shocked Steve.
Post #560920 Sat Jul 07 2018 11:26am
Jase
Wales
No must have missed that??
Post #560921 Sat Jul 07 2018 11:28am
Jase
Wales
So having read through lots of posts, look at an 09-10 plate 3.6l v8 as getting a warrenty to cover a poss crank issue is a Rolling with laughter should i look for a fsh one or go for a sorted 2.7l?? Decision decision...
Post #561113 Tue Jul 10 2018 2:25pm
DrRob
Buy the 4.2 Supercharged one in for sale section on here. No crank issues and big grins Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #561127 Tue Jul 10 2018 5:25pm
