![]() | Home > Maintenance & Modifications > Suspension noise |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Is it a creaking type noise? Mine has started doing this. Apparently it`s common in this hot dry weather. Get some silicone spray on the ARB bushes. Not done mine yet...... |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
Steve
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Just put up with it till it rains, or drive it through a river. Mines the same since the hot weather arrived but disappears when the rain comes. It’s all to do with surface rust in the bushes. I lubed it with silicon spray and that lasted a week, but my indi says all is well and my car is a 2013 with 60000 miles. |
I forgot to say well done for buying a RRS, I’m on my fifth LR and wouldn’t be without one.
Thanks Phil
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
As my ne ARB bushes done last yr by an Indy with oem parts so into dealer to be replaced under warranty |
If you want to get at all the bushes then take the wheels off, otherwise get her up to off-road height, secure with axle stands and leave a door open to prevent inadvertent lowering. When you get under you can see all the potential “squeakers” and a good spray may well help. It may be the anti roll bar bushes or the suspension arm bushes. Try to identify whether its rear or front.
Phil
So you had new bushes and now your returning it back to the main dealer to have the same work carried out under warranty Is my understanding correct buddy? |
Same age range as me then ![]() ![]() |
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
I have this exact problem - it's embarrassing - makes my Sport sound like an old banger. Only started happening the past couple of weeks so would fit with the dry weather thing.
This will give you an idea of what to look for |
micknolan Member Since: 19 Apr 2017 Location: West Midlands Posts: 45 ![]() ![]() ![]() |
I have sprayed mine 2-3 cans £15 over a few days.
Does get you down some days.Inmy case a 20k car.
